DK40 front bearing failure @ 1300 hours
   / DK40 front bearing failure @ 1300 hours #31
oercheron, thanks for the post! I too have a DK45, with 1000 hrs. My tractor is used for haying, so I never considered the loader to be carrying a lot of weight, however I do carry 700/800 lbs all around my hay field quite a bit (10 square bales + the grapple..it does add up).
Before the spring cutting, I will inspect the bearings; and report back my findings.
Thanks for the heads up!
   / DK40 front bearing failure @ 1300 hours #32
Sounds like with your use you might be OK, but it will be interesting to see what your bearings look like. I usually have 1500 - 2000 lbs in the bucket, and traveling over rocky, rough ground. That is pretty much all I do with this tractor.
The front axle oil needs to be changed every 400 hrs, that would be a good time to check as you lose all the oil when you take it apart anyway.
   / DK40 front bearing failure @ 1300 hours #33
Do you happen to have the bearing numbers available? Is the gear oil responsible for lubing these bearings? Would a higher quality synthetic or more frequent oil change extend the life of these bearings?
   / DK40 front bearing failure @ 1300 hours #34
Bearing numbers are 6208 and 6209.
Gear oil does lube these bearings, and I was using synthetic gear lube. Maybe more frequent changing would help, but mostly I think the problem is caused by the stress I put the axle under. Front tires buried in mud and rocks nearly to the top, down in some hole that needs full power to pull out of, and a full bucket. Day after day. I am really surprised that the machine stood this abuse so well for 1000 hours. But those are the job requirements, and extra repairs are factored in to my prices.
   / DK40 front bearing failure @ 1300 hours #35
Great. Thank you
I wonder who Kioti uses for the OE bearings? Maybe there is a better brand out there?
   / DK40 front bearing failure @ 1300 hours #36
Great. Thank you
The Kioti dealer supplied the bearings for the left side. He said that he just gets them from a local automotive supplier. The right side I did 2 weeks later and bought them from a local bearing house as that was closer. The kioti dealer charged me just a couple of dollars less than the bearing house. Very fair I thought.
All the bearings were name brand, Timken or such.
   / DK40 front bearing failure @ 1300 hours #37
I see that this is an older thread but since the same thing happened to my DK45SE at around 1000 hrs I thought it may help someone else for me to comment.
The left front bearing failed catastrophically, taking out the axle shaft and cover. Cost was about $1000 CAD for all the parts, I did the labour myself.
After repairing the left side, I took the right side apart. Bearings were horribly scored and looked to me near failure. I replaced them, an easy job, cost about $75 and both bearings were standard automotive type, available anywhere.
My use of this tractor is almost always as a loader, and I usually carry a bucket full of heavy material (gravel, boulders, concrete blocks) a long distance over rough ground. In addition I have added a spill guard to the top of the bucket and a cutting edge to the bottom, increasing its capacity. I do have about 850 lbs counterweight.
I will from now on be replacing front wheel bearings at around very 500 hrs, as they are not all that expensive, and it is not a big job to change them.
Thanks for the information. I plan on opening mine soon here at 500hrs for inspection and reporting back. I would call my loader use average. With every bit of useful info we can get on this thread we can come up with an hour count where we all should start thinking about changing the bearings in maintenance, depending on usage.
Did you keep up with greasing the upper bevel gear bearing?
It does continue to sound like these bearing failures are coming from heavy loader use. No problem there, its just good to know what and when to expect.
   / DK40 front bearing failure @ 1300 hours #38
Too bad these bearings are not roller style instead of ball type. Roller bearings will take a lot more load than a ball style bearing.
   / DK40 front bearing failure @ 1300 hours #39
Yes I keep up with maintenance according to the schedule in the manual.
You can see some of how the tractor gets used on my YouTube channel at muleskinnerjack
- YouTube
The video titled "Making gravel for the trail" shows the DK45SE being used.
   / DK40 front bearing failure @ 1300 hours #40
Be forewarned, the following has not been tested in this specific application in any way. Just "thinking out loud"
After reading through SKF's bearing book, I would say that their NUP208ECP and NUP209ECP roller bearings could possibly be a suitable replacement for the 6208 and 6209 ball bearings. Beyond just their correct sizing, these rollers have a dynamic load carrying capability double that of the 6208 and 6209.
18kn to 62kn and 35 to 70kn respectively.
I believe NUP would be best due to its availability and inner outer race retention specifically designed to locate a shaft axially in both directions. ECP should allow for oil bathing. However, there is a certain amount of axial play these single row rollers would have due to their nature that a double taper roller would handle better, but they are out of the game due to size requirements. Even still, SKF shows an axial tolerance of 0.05 to 0.15mm, so very little.
All things considered, I think these rollers would be worth testing should someone find themselves curious enough and willing to take a risk.
NEW Mini Excavator Fixed Thumb Attachment (A53002)
NEW Mini Excavator...
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
2014 INTERNATIONAL MA025 (A52472)
2014 INTERNATIONAL...
Krause 8200 Cushion Flex Disc (A52349)
Krause 8200...
2011 INTERNATIONAL MA025 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2011 INTERNATIONAL...
