Does the f250 Super Duty make the f350 obsolete?
   / Does the f250 Super Duty make the f350 obsolete? #41
I didn't realize any of the SRW 1-tkns were over 11k now. But my last truck shopping was 05ish models
My 06 F350 SRW was 11,500#. As Far ask know that is still what the Fords are. My neighbor has a 2012 SRW F350 and his is 11,500# also.
Chris
   / Does the f250 Super Duty make the f350 obsolete? #42
I dont need an F350, with an F250 I'd take the downgrade option to 9,900 pounds.
Driving a 350/3500 up here in Ontario means commercial annual safety and paperwork.
A 2500/250 is all I need. That gets me an 8' box and a full crew cab.
Again, all a govt, registration, paperwork thing. There isn't as much difference in the trucks as the govt implies.
Chris
Not well versed on the fords. But the Chevy's of the 05 ish era I researched were 9000-9200 for a 3/4 ton and 9900 for a SRW 3500. And the drw were 11-12k. And the dodges were similar but a tad higher on the drw trucks. My 05 being 12.2k.
I know some of the new drw trucks are insane with pushing 6-7k payload and 13k+ gvwr's
And it seems a modern 1/2 ton is more capable in both payload and towing than a SRW 350/3500 of the 1990's. But the govt would have you believe otherwise with the cost of tags/insurance. It seems as though jncle Sam aint keeping up with the times.
Again, I understand why so many choose the 250/2500 trucks for title, registration, insurance purposes. But that's really about it, as the srw 350/3500's are (should be) the same class of truck
   / Does the f250 Super Duty make the f350 obsolete? #43
The difference being annual safeties, stopping at the scales vs not. i'll take not.
   / Does the f250 Super Duty make the f350 obsolete? #44
Semantics. The point remains the same.....the real difference between a 250 and 350 SRW is next to nil. The govt is the one claiming a big difference, and separating them into two classes, whick is why your choice for the 250.
Look back 10 years ago.....or 20 years ago....
Truck ratings keep going up. Govt regs follow with the class of the truck and not what it's actually capable of.
I can cite a few trucks where the SRW 1-ton has less payload, less gvwr, and less towing capabilities than a 3/4 ton. Yet the lesser capable truck, in certain areas, cost more to own, register, insure, and have more "hoops" the driver must jump through.
You could simply make the SRW 1-tons a "higher payload" option for the 3/4 ton. But having two classes for otherwise the same truck is silly IMO
   / Does the f250 Super Duty make the f350 obsolete? #45
The old designations of 1/2 ton, 3/4 ton, and 1 ton are not relevant any longer. The better way to compare is the GVWR rating of the vehicle. A Chevrolet 3500HD Crew Cab/Long Box SRW with the 6.0 engine and 4:10 gears has a payload capacity of 4,147#. Same truck with dual rear wheels can carry 6,111#, 1 ton more, yet they would both be called "1 ton" by the old terminology. I believe the manufacturers still use the old designations, for example GM uses 1500, 2500, and 3500, simply for marketing and to compare to other brands, Sierra 1500 = F150 = Ram 1500. Who knows some day we may use the DOT classification. The DOT Class 1-3 are classified as Light Duty.
GVWR
Class 1 0 - 6,000 lbs
Class 2 6,001 -10,000 lbs.
Class 3 10,001 - 14,000 lbs.
Class 4 14,001 - 16,000 lbs.
Class 5 16,001 - 19,500 lbs.
Class 6 19,501 - 26,000 lbs.
Class 7 26,001 - 33,000 lbs.
Class 8 33,001 lbs.+
Picked up the new truck tonight... leap day so it will be easy to remember.
Almost 12 weeks start to finish from when the order went in... also picked up an extra $750 Ford rebate that happen to come along.
Was surprised to see the new aluminum body 2017 Super Duty Brochures out... looks like we got the last of the steel cabs with the 2016 and made in Kentucky.
They also had several Raptors plus f450 and f550 in stock... no 700 hp Shelby Pickups.
Our crew cab 4wd has a payload of 3,000 lbs with the 9900 derated GVW which is the lowest... the highest f350 crew 4wd is 4270.
Conventional Bumper towing for our F250 4wd is 14,000 lbs and for 5th-wheel/gooseneck towing is 15,100 lbs
Conventional Bumper towing for F350 crew 4wd is 14,000 lbs and for 5th-wheel/gooseneck towing is 15,700 lbs
Did find the F350 dual crew with duals up to 19,000 bumper and 26,500 for 5th wheel camper package...
Time will tell how well it pulls and handles trailers/loads...
PS... seems the State of California has a fee schedule on new super duty pickups based not only on GVR but also towing...
Guess another formerly untapped revenue stream.
   / Does the f250 Super Duty make the f350 obsolete? #48
I looked into the 6.2 until I found out it has 16 spark plugs.
With the way spark plugs last on today's vehicles, how often is that going to come into play? More for some than for others, but I think you're basically talking about every 100k miles.
   / Does the f250 Super Duty make the f350 obsolete? #49
Picked up the new truck tonight... leap day so it will be easy to remember. Almost 12 weeks start to finish from when the order went in... also picked up an extra $750 Ford rebate that happen to come along. Was surprised to see the new aluminum body 2017 Super Duty Brochures out... looks like we got the last of the steel cabs with the 2016 and made in Kentucky. They also had several Raptors plus f450 and f550 in stock... no 700 hp Shelby Pickups. Our crew cab 4wd has a payload of 3,000 lbs with the 9900 derated GVW which is the lowest... the highest f350 crew 4wd is 4270. Conventional Bumper towing for our F250 4wd is 14,000 lbs and for 5th-wheel/gooseneck towing is 15,100 lbs Conventional Bumper towing for F350 crew 4wd is 14,000 lbs and for 5th-wheel/gooseneck towing is 15,700 lbs Did find the F350 dual crew with duals up to 19,000 bumper and 26,500 for 5th wheel camper package... Time will tell how well it pulls and handles trailers/loads...
I seriously doubt your crew cab F250 diesel truck only weighs 6,900#
I would take it to the scales and weigh it with a driver and say 2/3 tank of fuel then subtract that from the 9,900# GVWR to get your true payload capacity. I think you will find the truck is around 7,500# leaving you only 2,400# of payload which is the big issue with the 3/4 ton trucks of today and the reason why everyone around here goes for the SRW F350.
If pulling a BP trailer you need 10% tongue weight. If the max tow rating is 14,000# that means 1,400# on the tongue. That leaves you only 1,000# for people and cargo in the bed. That may work for some. The real issue is using a 5th wheel or GN. You need 20% on the ball. That's 3,020#, and over your usable capacity. If the truck weighs what I think it does you would be limited to a maximum 5th wheel or GN trailer weight of 12,000#.
So you are actually able to tow more with a BP trailer Thanatos 5th wheel or GN trailer. This is where the extra 1,600# of payload capacity of a F350 SRW truck makes them shine. So much more usable capacity!
Chris
Only going off the printed specs from the order sheet...
It was dark last night when we were picking up or I would have taken a couple of pictures.
Truck was also derated to come in under 10k... per the dealer everything is the same had it not been and the GVW is higher than stickered.
I'm curious as to what it weighs... all the local scales are gone... might have to make a dump run.
It will be a learning curve as new equipment always is... the biggest trailer owned is a 12k PJ that is also derated... seems derating is very common in California.
The dump trailer has a 5k payload for the one bought new...
My home made dump trailer has carried this much also... as it was home made by me 35 years ago with a new surplus axle and spring set given me... not really sure of rating... it has 8 lug 16" rims.
Being able to operate and not being subject to freeway weight restrictions and weigh stations plus all the extra requirements/taxes that kick in at 10k is a big consideration...
JOHN DEERE 450K LGP CRAWLER DOZER (A52707)
JOHN DEERE 450K...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
207010 (A55853)
207010 (A55853)
Kubota LX2620 (A53317)
Honda EM3800SX Generator (A55851)
Honda EM3800SX...
