Electric Fence Options of Mini Horses.
   / Electric Fence Options of Mini Horses.
So the + and - connect to the tape and so a standard charger will work ?
   / Electric Fence Options of Mini Horses. #32
I've only installed 1 electric fence and it was Horse Guard using their charger. I presume it's the same setup as others. Their charger has 1 positive and 1 negative connection. You do need to use their hardware and connectors.
Cool. We will check that out because portability is important to me so loosing the need for grounding rods would be huge. Thanks
   / Electric Fence Options of Mini Horses. #34
+ from the charger goes to the tape. - from the charger goes to the ground rod(s).
   / Electric Fence Options of Mini Horses. #36
My bad. I have not seen one of these chargers and should have looked first.
I do not think it is charger brand specific. The path is on the horse and does not flow through the ground like they have worked all of my life. :)
Not sure bipolar wire will work with Zareba chargers?
   / Electric Fence Options of Mini Horses. #40
A charger is just a charger. The Zareba should work. I just checked out the Horseguard Fence. Pretty interesting fence. Looks like you are on the right track. Would be interested on how well you like the Horseguard Fence.
2012 Cadillac SRX SUV (A55758)
2012 Cadillac SRX...
Behlen 150 Gallon Premium Stock Tank (A55218)
Behlen 150 Gallon...
2006 Chevrolet Impala Sedan (A54815)
2006 Chevrolet...
2001 Freightliner FL80 E-One Pumper Fire Truck (A52377)
2001 Freightliner...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
Plasmarc PM150 Plasma Cutter (A54811)
Plasmarc PM150...
