Experience with making an arena
   / Experience with making an arena #1
GrantMO
KC area
Kubota L3410
Late last fall I posted a similar question on Yesterday's Tractors and I wanted to see what youralls experience has been with making an outdoor arena. God willing, we might be able to do this project this summer, unlike the creek project from another thread.
My wife is looking to make an outdoor riding arena 100x200 feet. Since the site in question is pretty flat with deep topsoil I won't have to move huge amounts of dirt but will have to take off some sod in places and crown it for drainage.
Keeping in mind that my first goal is cost containment, my questions would be: would a box scraper and rear blade do the job? How much crown would provide for good drainage? Is compacting the top soil necessary prior to adding the footing (sand) ? I appreciate your responses.....
   / Experience with making an arena #2
Grant,
Now you're talking my speciality!!! Give me specifics on exactly what you want the arena for and what you are going to be doing. I have built alot of arenas both indoors and out. I may have a better way than worrying about crowning too that will save you alot of time keeping the arena nice. For equipment all you really need is a good disc and a harrow if the ground is already flat. Let me know and I'll get you going for little money at all.
   / Experience with making an arena #3
cowboy doc I'll be following this post closely. We put in our indoor already but are in the process of making the outdoor. We had to move about 2 feet from the high side to the low side so I hired out to a dozer. Took him about 8 hours so i know it would have taken me forever with my compact. So far we have a flat area and are waiting for settling after the spring thaw. I was considering getting it rolled for compression before putting down footing but was interested in your ideas for drainage. Are you talking drain tile?? PS I know I still owe you a picture of my "manure screeen" in action - it's really so simple I'm almost embarrassed to post it but I will!!
   / Experience with making an arena #4
Doc Richard...here are my aches and pains in the arena region. Is there hope...?
1) 80x200 covered, perimeter-sheathed w/ exterior treated OSB 4x8 sheets varying 3-6 inches below the riding surface; native sandy loam soil aprox.
12-15 feet deep w/pocket ribbons of hardpan marble-ing 8-10% (fairly bustable grey, not blue); overhead watering system is 6 zone x 3 impact rainbirds per zone, 1-zone-on-at-a-time, auto controlled sequence and duration (whew!)
PROBLEM: "washboard" woop-de-doo's starting to appear now, after 2 years or so of successfully being able to drag/groom the surface with a chain harrow/drag pulled w/ my JD 4200. I used to be able to level the whole buckwheat in 20 minutes going slow and easy! Once or twice a season I would clump-bust the whole surface with a boxblade, teeth set fairly deep. After this homogenizing plow, I used to be able to drag the surface, points down, then points up with the chain-harrow, zip the ol' railroad tie across slowly and BINGO it looked like a brown, felt snooker table for the Jolly Green Giant. Alas, not lately. Any cure, Doc? Please don't say, "Quit sniveling and rent your arena out as a Moto-Cross
course!" Not a bad idea...or maybe a Miniature Golf Course...Driving Range(naw, I usually have to PUTT 200'!)
Lazy K - Chip
   / Experience with making an arena #5
Chip,
Anyway to get me a picture of what it looks like? I think I know what you're talking about. What I don't know is are the humps caused from the marbling coming through the sand or are the humps caused from only the topsoil being worked? Without knowing more here are two suggestions about what to try until I know more. There are two ways to go about this. The first is the cheapest and may or may not work. What you need to do is get a two or three bottom plow and plow the whole thing up as deep as you can go. You may have to get a bigger tractor I'm not sure what the 4300 will do. Plow it both ways, north and south, and east and west. Next get a really heavy disc and disc it as smooth as you can get it. After this you should be able to start over again with the way you used to dress the arena. Now if your problem is actually the soil moving then you've got a more serious problem. Let me know some more before we go into that route. Remember though when you do drag no matter what anyone tells you, only dress the top 2-4" of an arena. If you do more it's way too hard on a horse legs to move in that kind of arena. I've seen alot of horses ruined from footing being too deep.
   / Experience with making an arena #6
Gerard,
You bet tile it! Buy the tile with a sleeve on it. You can get it here for $24 for a 200 foot roll, CHEAP! Then in your arena tile from the high to the low side or use a level and just keep angling it down to where it's going to come out at. Put in the tile on the short part of the arena, ie if you ahve a 80x200 arena put the tile lenghtways across the 80 foot part. Do this every 15 foot. I have done this on the arenas I've built out here, Iowa where there is alot of rain, and you can ride the day after even a big storm. Make sure and go at least a foot deep though so you won't snag them when you groom your arena. I also did this in my round pens and I can go out there two hours after it rains and work in it.
   / Experience with making an arena #7
Sigh, its threads like this that remind me just how ignorant I really am. Ok, what is "tile"? I thought it was that hard, glazed stuff that you put in the bathroom/w3tcompact/icons/blush.gif, but I always here people talking about it whenever drainage comes up. I figured from their talk it was some sort of conduit... is that right?
mark
Richard,
We plan to use the arena for jumping, training the Clydesdale probably including a cart at some point, and general riding/training. We're not absolutely set on the dimensions but probably can go only another 50 feet either way and still stay flat. I was planning on about 3 inches of sand. So, the tile drain is the way to go? I may not be able to run the tile across the short side but I'd have to go look to really say for sure. Sounds like the middle buster would be an easy way to dig the drainage trench.
Mark,
If I'm on the same page as Richard, the tile is the black plastic slotted flexible tube you see put in around the base of the foundation on houses, then covered with gravel.
Richard, I'm in luck that I have access to my friends JD 620 and a 10 foot or maybe bigger disk. I don't think anything I could pull behind the 8N would do the job for disking. It would do okay for harrowing.
   / Experience with making an arena #10
Grant,
If you get the tile with the sock no need to put in gravel over it. My one arena that I've had for six years now still drains great and all I did on it was cover it with dirt.
Now as far as your arena goes I would just use the soil that you have. Are you going to just practice or are you going to use this for competitive jumping? If it's just for you and praticing and you want to save money I wouldn't even get sand. Just keep the top four inches nice and harrowed up or get one of those arena groomers with the money you'd save from having sand hauled in. Initially you'll want to plow and disc it up and then after that just work the top 2-4". If you do decide you absolutely want to go sand you have to get the right sand. Don't get just regular river sand as it is not very good for horses and if you ever feed in the arena you always have to watch out for sand colic and feed a sand remover. In my opinion unless you have an indoor don't even bother with sand, way too much cost for the little benefit. Also it gets washed away really easy, etc.
Ok now for the building of the arena. If you really want to go cheap you can build one for less than $1000 six' tall that is sturdy and isn't cheap looking or you can go really fancy. I'll start with the simplest, cheapest and sturdy. Then if you want more ideas I'll be glad to help. As soon as I get my digital back I can take pics of any arena that you may want and send to you. Ok the easiest one to build is out of 2x6's, horse woven wire, and railroad ties (you can use any posts that you want but the ties are usually the cheapest and sturdiest). For a 100x200 you will need 60 railroad ties, 60 2x6's, and two rolls of woven wire. Here in Iowa for the one I built last year I got the ties for $6 a piece, the 2x6's were rough cut from a local saw mill out of oak for $5 a piece and two rolls of woven wire was $75 a roll. For your arena this would have been $810. I spent a little more but I made mine a roping arena so there was the building of the chutes and the return alley. Basically you build it with the ties 10 foot apart. Get five foot tall horse fence and then go six foot and put the 2x6's on top of that. The 2x6's that I get are rough cut and then I treat them every year so they last. That's the basics there. If you want to go with this one I'll get you a pic of the one I have here. Your other option if you don't want to build one is to buy the panels and put one together yourself. You can take a look at one of these at www.redriverarenas.com. They are a little pricey but you have the convenience of always being able to move and little effort putting it up. Another thing to consider is putting up a three sided shelter on the end of the arena. This way you have another place to keep horses, cattle, etc. The one I put up last year with the arena was only $1100 and it was 15x36. Your other options, but more expensive, are to do it all out of wood, pvc fencing, etc. I've done or helped do them all so let me know what your thoughts are and I can help you out.
2008 DOOSAN G25 GENERATOR (A58214)
2008 DOOSAN G25...
JOHN DEERE 4450 TRACTOR (A60430)
JOHN DEERE 4450...
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A56438)
2022 John Deere...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A56438)
1992 Talbert 70...
2013 FORD F250 (A60460)
2013 FORD F250...
5ft Pull-Behind Rotary Tiller Tractor Attachment (A59228)
5ft Pull-Behind...
