jejeosborne
Maybe when it time for you to buy they will be putting the ecoboost in the f250 and you can have the best of both.
Put a gooseneck in the F250 and tow 16000. 4700lbs.
My current tractor with heaviest single implement weighs around 9000 lbs. I use a 82" x 22' 12K bumper pull equipment trailer when I move it. Total combined weight of tractor, implement and trailer is approximately 11,500 lbs. I don't know the exact weight on the trailer but estimated 2500 lbs. I usually tow this set up three or four times each year approximately 30 miles to the hunting lease. My current daily driver and tow vehicle is a 2004 F150 with the 5.4 V8 and 3.73 gears. I am not currently in the market to buy, but like to plan ahead for major purchases. I have been torn over whether to consider a F250 for my next vehicle or stay with the F150. I typically keep a truck 10 years so want to make the right decision. I like the idea of the diesel, but see them as too much maintenance and cost. I currently get around 14-16 mpg with the average closer to 14 mpg. I think the F250 gas burner would be very close so mileage not a deal breaker. Curious to hear thoughts on this and why.
You really ought to put the trailer/tractor combo on the scale and see EXACTLY how much weight you are REALLY towing. Not guessing.
Got a friend that runs the shop at local Ford dealership. Messaged him and he too thought they were different. Said he would have to run a VIN to make certain, but thought the engine choice determined the drivetrain components. I ASSUMED they would keep it simple and keep them the same.
The F250/F350 srw currently are basically all the same components and have been for a long time. What you get different:
2 vs 4" lift block on the rear end 250/350
Different rate spring packs/coils depending on option codes, in some cases the diesel gets close to the max spring rate and there aren't any ++ options.
5.4 L has only 2 sidegears in the same 10.5" rear axle as it is putting less torque through diff. (this isn't always true, some 5.4's got the v-10/diesel carrier +side gears)
F250 has lighter+smaller tires and in some cases lighter duty rim options - but not always.
Bellhousing casting on transmission different.
Torque convertor specs different (obviously)
They have the same transmissions, transfer cases, driveshafts, wheel bearings, ring and pinions, axle shafts, brakes, rear springs, frames, etc regardless of engine. Frame psi/thickness based on the wheel base.
