Five star post hole digger ?
/ Five star post hole digger ? #1
jerbear2
Wisconsin
Ford 2910
Was wondering if you could help me that I can not come up with? On the photo I am sending how do I get the adapter off the shaft ? Do you think it is pressed on [ no keyway] or could be it threaded right or left. I need a new seal and have to get adapter off. I think it is a five star post hole digger ?. I tried to get off with heat & 12 ton press & no go. Put in big vice and heated with torch tried to turn with big pipe wrench & no go.
Thanks
Jerry [ Wis.]
PS. Looking on Comp. at other diggers and a lot have same gear box but no adapter & not threaded just holes. Cant find break down for five star gear box.
/ Five star post hole digger ? #2
*It looks like a Comer gearbox, but could be an Omni, not unique to Five Star. *Is there another pin higher up the bushing securing it to the shaft? **
The bushing is just that, just slid onto the output shaft and probably stuck with rust and dirt. More heat on the output shaft. Possibly drill a hole through the end if it is solid and get penetrating oil through that end.
*( Five Star is now Superior Companies, *Dewey, Oklahoma and they don't manufacture posthole diggers anymore)
No pin higher up. Could it maybe have a spline to hold it from slipping ? The photo of gear box is not like mine. Mine is more round on bottom. Going to give it more heat & drill hole think it could be rust.
Thanks for reply
Jerry Wis.
/ Five star post hole digger ? #4
Now that I've given this some thought(I sold new 5 star diggers way back when) AND I COULD BE WRONG but I think adapter screwed on gearbox shaft.
Hi
You are correct I took it to a machine shop today and they tried everything and ended cutting off the adapter with lathe and found threads. Now have to make new adapter. Wish I had seen your reply before I went to machine shop. Thank you any way.
/ Five star post hole digger ? #6
I'm sorry I couldn't get my chickens gathered quick enough to save your adapter. Just goes to show you even a blind hog can find an acorn every once in a while.
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2016 JOHN DEERE 7210R TRACTOR (A65054)
2016 JOHN DEERE...
2008 PROGRESSIVE 20' X 7' BUMPER PULL TRAILER (A65643)
2008 PROGRESSIVE...
Chevy 2500 HD 4WD (A63689)
Chevy 2500 HD 4WD...
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
2007 Ford F750 Dump (A62613)
2007 Ford F750...
