Flakes of hay - variation?
   / Flakes of hay - variation? #1
weedsportpete
Weedsport, NY
BX2200
Hello everyone - I've got some basic questions about bales of hay, especially what things influence how a bale will flake apart and how it flakes apart.
I've noticed differences in bales, some of these tend to run in a particular batch we get from the farmer who sells it to us. Other times it seems to vary from bale to bale.
I'd love to be able to pull flakes apart in widths of two inches, or sometimes three inches. Some bales come apart in just that size, others are loose and some only come apart in four to five inch flakes. I try to break these up, and while one end of the bale is loose enough that I can pick the spot where I want it to break, the other end is so tightly intertwined that I end up shredding most of it.
I've also noticed that the bales are shorter, by about half a foot, this year, as opposed to last year.
Can farmers and their equipment adjust the baling so that they can set the width of the flakes?
Can they set their baling so that both ends of the bale are loose enough to pick apart, instead of only one end?
Should all hay baled in one batch be consistent?
Can they shorten or lengthen bales easily? Is this a 'buyer beware' situation?
Some bales are kind of dusty when pulled apart. Is this caused by the cut hay getting baled too quickly?
Thanks in advance.
   / Flakes of hay - variation? #2
The answer is yes to all of your questions. It's very easy to vary the compaction, length, etc. of the bale. Hay should not be dusty at all when it is opened. It's either poor quality, was cut at the wrong time, etc.
   / Flakes of hay - variation? #3
Let me elaborate on Richard's explaination to say that dusty hay is actually a mold situation caused by bailing at to high moisture content.
Moldy (dusty) hay is bad for an animals digestion system and their noses too.
Thanks.. Wanted to hear it from people who know it.
If you had or would sell your hay to other people, how receptive are you to them asking you to adjusting your baling to get a certain compaction and size of the bales?
   / Flakes of hay - variation? #5
It's always better to buy hay by the ton .
That way, bale size is unimportant. A ton of hay is a ton, no matter what the bale size is. Problem with that is some folks that sell hay try to get a big bang for little weight.
Tell your supplier that you'd prefer to bu by the ton.
As far as compaction, all he has to do is adjust the tension on the bale chute.
   / Flakes of hay - variation? #6
Most proffessional hay producers around here try to regulate the size of bales so that they are consistant in weight.
However, as a rank amateur in the baling of hay, I'm just happy if my bales hold together and are generally somewhat square in shape!! /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
   / Flakes of hay - variation? #7
Shape and size are mostly the function of the bailer. If you are having troubles like that, I'd suggest some adjustment to the bailer. Most likely performed by a technician who knows the bailer.
   / Flakes of hay - variation? #8
Thanks, Daryl. Actually I did that, and I have no troubles anymore.
But...I'm just still thankful that they come out tied and square!!! So many things can go wrong with a baler, I'm always thrilled when it works. And my NH 273 almost always works just fine. /forums/images/graemlins/grin.gif
   / Flakes of hay - variation? #9
Too funny.... /forums/images/graemlins/grin.gif
Don't worry though, it is an aquired trait and you seem to be doing just fine!
-Regards.
-Mike Z.
   / Flakes of hay - variation? #10
Rich,
It's even more of a bummer when a big round bale does not come out right. Thats 1200lbs of hay rather than 60 lbs.
The good news is that in comparison a round baler is much more simple in operation and there are just a few things to watch out for, like running out of twine..... /forums/images/graemlins/blush.gif
Fred
2015 MACK CHU613 DAY CAB ROAD TRACTOR (A58375)
2015 MACK CHU613...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2021 CATERPILLAR D5 LGP HIGH TRACK DOZER (A60429)
2021 CATERPILLAR...
LIMA MAC 60KW GENERATOR (A58214)
LIMA MAC 60KW...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
Freightliner Tender Truck - Adams Tender (A56438)
Freightliner...
