Loader Flipped my L48 Kubota
   / Flipped my L48 Kubota #141
How does one cut off the fuel supply on a tractor? I thought shutting the key off would of done that.
In a normal situation my key cuts fuel flow. But there is a manual cut-off at the injector pump also.
Sent from my iPhone 2.0 using TractorByNet
   / Flipped my L48 Kubota #142
Grasshopper, some machines have key-off-fuel solenoids, others have mechanical cable or lever operated fuel shutoff, including dump throttle models. All should have a valve on the tank outlet though, with some exceptions.
   / Flipped my L48 Kubota #143
So is that what OP did you think, shut the fuel off at the injector pump. Next time I look at my tractor, I'l see if I can find that manual shut off.
   / Flipped my L48 Kubota #144
Mine are on the dash. Most are pull buttons. On one the hand throttle has an extended stop position.
   / Flipped my L48 Kubota #145
Permatex makes a nifty head gasket spray. I use it on both sides.
I would have reused it with coppercoat. It would not leak then. I haven't put a head gasket on without it after a co-worker at a car dealer told me about it. My buddy uses the $1/can aluminum color spray paint because he thinks coppercoat costs too much.
   / Flipped my L48 Kubota #146
I would not have known where mine was or that it even existed without reading about it here on TBN.
   / Flipped my L48 Kubota #147
It's easy to think one could kill the air to a Diesel engine after it has flipped over but in the heat of the moment things are happening fast and finding the air intake or manual fuel shutoff can be a daunting task when you are upside down.
I think a quicker way to kill the engine would be simply to plug the exhaust system as most are accessible easier than the intake. A pair of gloves or any way to try to tightly plug the exhaust. If the system is tight enough it should work.
Maybe practice it a few times on your machine to see if you can stall the engine at full revs.
Fred, hoping never to tip over.
   / Flipped my L48 Kubota #148
driveway, are the head bolts stretch bolts? How many times can you reuse them?
   / Flipped my L48 Kubota #149
if it's laying on the side of the air cleaner and intake manifold, it may be difficult.
A large ball valve in the intake might be good for any diesels running around escaping fuel gas ( lp, methane, etc.. )
You would think that. And that's what i thought. But turning the key off did not work. Luckily, the L-48 has a manual fuel shut off on the filter head so you can turn the fuel off while changing the filter.
PALLET OF JACKS AND JACK STANDS (A58214)
PALLET OF JACKS...
New/Unused Quick Attach Auger with Three Bits (A57453)
New/Unused Quick...
Unused IRTPL 10,000lb Two Post Car Lift (A55272)
Unused IRTPL...
10ft. S/A Utility Trailer (A56859)
10ft. S/A Utility...
2024 Yakta YXR120 Zero Turn Lawnmower (A57453)
2024 Yakta YXR120...
2018 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A59575)
2018 FREIGHTLINER...
