Loader Flipped my L48 Kubota
   / Flipped my L48 Kubota #141
How does one cut off the fuel supply on a tractor? I thought shutting the key off would of done that.
In a normal situation my key cuts fuel flow. But there is a manual cut-off at the injector pump also.
Sent from my iPhone 2.0 using TractorByNet
   / Flipped my L48 Kubota #142
Grasshopper, some machines have key-off-fuel solenoids, others have mechanical cable or lever operated fuel shutoff, including dump throttle models. All should have a valve on the tank outlet though, with some exceptions.
   / Flipped my L48 Kubota #143
So is that what OP did you think, shut the fuel off at the injector pump. Next time I look at my tractor, I'l see if I can find that manual shut off.
   / Flipped my L48 Kubota #144
Mine are on the dash. Most are pull buttons. On one the hand throttle has an extended stop position.
   / Flipped my L48 Kubota #145
Permatex makes a nifty head gasket spray. I use it on both sides.
I would have reused it with coppercoat. It would not leak then. I haven't put a head gasket on without it after a co-worker at a car dealer told me about it. My buddy uses the $1/can aluminum color spray paint because he thinks coppercoat costs too much.
   / Flipped my L48 Kubota #146
I would not have known where mine was or that it even existed without reading about it here on TBN.
   / Flipped my L48 Kubota #147
It's easy to think one could kill the air to a Diesel engine after it has flipped over but in the heat of the moment things are happening fast and finding the air intake or manual fuel shutoff can be a daunting task when you are upside down.
I think a quicker way to kill the engine would be simply to plug the exhaust system as most are accessible easier than the intake. A pair of gloves or any way to try to tightly plug the exhaust. If the system is tight enough it should work.
Maybe practice it a few times on your machine to see if you can stall the engine at full revs.
Fred, hoping never to tip over.
   / Flipped my L48 Kubota #148
driveway, are the head bolts stretch bolts? How many times can you reuse them?
   / Flipped my L48 Kubota #149
if it's laying on the side of the air cleaner and intake manifold, it may be difficult.
A large ball valve in the intake might be good for any diesels running around escaping fuel gas ( lp, methane, etc.. )
You would think that. And that's what i thought. But turning the key off did not work. Luckily, the L-48 has a manual fuel shut off on the filter head so you can turn the fuel off while changing the filter.
Metal Donkey (A57454)
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2014 Grove TMS700E 60 Ton 4 Section Quad Axle Crane Truck (A60460)
2014 Grove TMS700E...
2019 CATERPILLAR  XQ60 GENERATOR (A58214)
2019 CATERPILLAR...
1 Ton Mini Excavator Hydraulic Thumb (A57454)
1 Ton Mini...
20ft Jumper Cables (A57454)
20ft Jumper Cables...
