Ford vs chevy vs ram SRW one ton diesel
   / Ford vs chevy vs ram SRW one ton diesel #111
Please explain the 10K threshold?? I don't get out much... :)
Could be for property tax reasons. Where I live they will blister you for anything over 10000#.
   / Ford vs chevy vs ram SRW one ton diesel #112
- Heads removed, inspected, milled, tested.
- ARP Head-Studs
- New Oil cooler
- EGR delete
- Coolant flush and non-Ford ELC (twice now)
- All new injectors (and all related parts)
- Stand Pipes, Dummy Plugs, 6.4 fuel rail banjos
- STC Fitting
- IPR valve & screen
- Turbo serviced (and related parts)
- New up-pipe, Y-pipe, 4" exhaust, no-cat
- also recently replaced batteries, alternator, intercooler pipe boots.
..... I think that's it lol
I thought a coolant filter was one of the first things folks installed on these motors??
   / Ford vs chevy vs ram SRW one ton diesel #113
Or just change out the coolant to ELC.
My dad has 6.0 work trucks in his construction fleet that get yearly coolant changes that have never experienced bad EGR or clogged oil coolers. They have upwards of 300K+ miles on them.
The 6.0 Powerstroke got it's bad rap from something as simple as people never changing their coolant.
   / Ford vs chevy vs ram SRW one ton diesel #114
We opted to de-rate the new F250 Diesel which is also a F350 no cost option.
Same truck with a lower rating to get under the 10k threshold.
The local Dealer said about half the F250 and 350 Diesels ordered are de-rated to come in just under 10k... helps a lot when set up for towing too...
In a perfect world such games would not be necessary....
There is no derating of F250 or F350 as far as motor or suspension goes. The only trucks Ford derates are chassis cab trucks and that is for duty cycle more than anything else.
   / Ford vs chevy vs ram SRW one ton diesel #115
When we bought our F350, we were offered an option code for 10,000 GVW. We need the full rated GVW (11,300) so we didn't take it, but that option seemed like "derating" , and correct, there was nothing physically different, and I think the GCWR would stay the same.
   / Ford vs chevy vs ram SRW one ton diesel #116
We have the de-rate option clearly identified on the window sticker... it applies to the GVW and brings it to 9900 on the F250 and 10,000 on the F350 scroll down the Ford link below and it shows this as an option.
216 Ford Super Duty F-25 XLT | Packages| Ford.com
It was a no cost option when we ordered.
There are local freeways with commercial GVW limits and scale requirements... plus Insurance over 10k is more expensive.
   / Ford vs chevy vs ram SRW one ton diesel #117
I'm still lost. 10K what?
   / Ford vs chevy vs ram SRW one ton diesel #118
I'm in California and different costs and regs kick in over 10,000 lbs.
The reality is to most law enforcement here is a pickup is a pickup.
My insurance provider mentioned he has to use a different rate schedule if the pickup has a GVW in excess or 10,000 pounds.
The Department of Motor Vehicles charges commercial vehicles based on GVW too... the higher the GVW the more the annual license cost.
Ford Motor Company must believe there are valid reasons or it makes sense to offer the option of a lower GVW door tag that does not exceed 10,000 on the F350 and 9900 on the F250
   / Ford vs chevy vs ram SRW one ton diesel #119
10,000 lbs. it is the threshold for many things, registration costs, etc. If using the truck for business purposes and crossing state lines and you are over 10k GVWR you need a dot number, log book, Med card, etc. Under 10k you don't.
   / Ford vs chevy vs ram SRW one ton diesel #120
I guess it's a California thing. My f250 is 10,000 on the door sticker and there was never any mention of wanting it any different.
Sometimes I forget how lucky I am to live in a state where these things aren't fussed over.
2012 Chevrolet Silverado 1500 LTZ Crew Cab Pickup Truck (A51692)
2012 Chevrolet...
1965 Rodgers T/A Equipment Trailer (A53117)
1965 Rodgers T/A...
BUSH HOG 1815R1 BATWING MOWER (A51247)
BUSH HOG 1815R1...
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
Trojan 35CL 40 mm Hydraulic Hammer, NEW (A52384)
Trojan 35CL 40 mm...
2011 WABASH 53x102 DRY VAN (A53426)
2011 WABASH 53x102...
