forgeing splines using a axle and press
   / forgeing splines using a axle and press
Looked everywhere for bushings and hubs. Nothing to be found around here. Made up a order to Surplus center and headed out fishing. Who says you cant do two things at once. I can wait on parts and fish at the same time.
   / forgeing splines using a axle and press #32
muddstopper has left the building
Didnt get to the lake, wife put my butt in the garden. Plan on planting corn this friday or sat if it dont rain.
Did take the time to draw up the geometry of the pitman arm and cyl connections for turning the axle. Didnt take a pic of doing this, but I think I want to explain How I do it. Maynot be the best way, but its the only way I have found to work consistantly. Plus all it takes is a scrap piece of wood and a tape measure and a drill.
First thing you need to know is the retracted lenght of the cyl you plan to use. Then the extended lenght. This will give you the total stroke. In my case, TS is 6 1/4 inches. In order to turn the axle 180 degrees. I can use the 6 1/4 stroke as the dia of the circle the pitman arm needs to make. I then take a framing square and draw a Large "T" on my welding table. The spot where the top of the T meets the upright portion is now my center of the Pitman arm. Since my stroke is 6 1/4 inchs, I measure out half that distance on the cross part of the T using the now established center point of the turning radius. I then take a paint stick, for lack of anything better, and drill a hole to use as the base and rod ends centers of the cyl. I make three holes, The base to rod at fully retractment and base to rod end fully extended. I then center the rodend full retracted measurement on the outer mark of the top of the T and use a pencle in the base end hole and use the paint stick as a protractor and draw a circle. Once The circle is drawn, I place the rod end hole fully extended on the opposite T marm and with pencle in base end, I draw another circle. Where the two circles cross is where the base of the cyl is mounted. If mounted this way, with cyl shaft centered in its stroke range, the boom will be at 90* or in line with the leg portion of the "T" and fully extended it will turn 90* ,inline with the Cross of the T and fully retracted, again 90*, inline with the cross of the "T. If you are using 2 cyl to turn the boom, when drawing your circles, just make full circles and the lines will cross again on the opposite from the first crossing and this is where you would mount the base of the second cylinder. If you dont want both rod ends of the cyl on the same pin you can make your steering arm long enough that you can mount your second cyl on the opposit side of the first cyl. Just start drawing circles again to figure out eh second cyl mount.Then plumbing you can make one cyl push and one cyl pull at the same time. Word of caution, If anything is hanging below the pitman/steering arm. there is a chance your cyl will hit it when fully extended, so it is best if you make your cyl rod mounts below the steering arm and not straddle the arm, as in a clevis. Also, if you are off just a little bit on your measurements, there is a chance your cyl will extend or retract more than is necessary to get the full 180 turn. If this happens, the cyl can cam over and try to turn the boom to far or not far enough creating binding when you want to change direction of the boom. You can also increase the dia of the steering arm to decrease turn radius, I just play with the numbers until I get the amount of turn I want. A compass comes in handy for doing that.
   / forgeing splines using a axle and press #34
I actually started working on the boom today. Got the hub apart. Cut some flat plate to bolt to the hub flange. Chucked the hub up in the lathe
Since you have a lathe you can accurately grind the end of the hardened spline into a 2 step broach profile. Grind the 1st step about .040 under for a tenth inch or so. Then starting from there grind the 2nd step ~ .020 under for another quarter inch. Break the sharp end edges on the 40 under tip. Press into a hole that is 40 under in the soft plate. The sharp ground edges on the spline will cut. Use plenty of moly.
i cant turn the axle on my lathe. Sticking the axle thru from the back of the chuck and it isnt long enough to cut on. The axle is to long to fit between centers. My lathe has a 14in swing, but only a 24in bed. I will have to cut the keyway using a hand grinder. The good thing is, the fish where biting this morning. Caught about 40 or so spotted bass, bream, and one nice channel cat.
   / forgeing splines using a axle and press #36
check local machine shops one of them might have the right broach and could easily cut the splines for you especially if you have the piece all ready I would check with them first to make sure what size pilot hole. Or you can see if you find a broach from an industrial supplier but might be expensive, anywhere from $200 to $300 for the right one. another option is make a guide on your lathe and get a key broach which should be relatively inexpensive and carefully cut each spline tooth individually if you don' t it quite right then hat it and press axle into your splines you cut.
   / forgeing splines using a axle and press #37
Your picture of the axle looks like a simple 1 3/8" diameter bar with a splined end. Is there a larger section out of the picture that won't fit thru the headstock?
Sure there is a larger portion, the axle flange that bolts to the hub. I havent measured it but its 3 1/2-4in in dia. I have a 1940's something gearhead monach lathe. The lathe head is pretty long. When I put the axle thru the headstock it doesnt come all the way pass the jaws of the chuck. It comes far enough I can run a drill in the tailstock to try and drill it, but none of the splines show pass the chuck jaws. If I chuck the axle flange in the chuck, the splines extend pass the end of the lathe bed. My cross slide and tool holders wont reach the end to do any machine work. If I chuck the spline end of the axle in the chuck, and the flange in the tailstock, then the work area is covered by the chuck jaws. Botto line, my lathe is to short to do any machining on the spline end of the axle.
I have consided many options to make this axle and hub work, the only part giving me any problems is attaching a pitman/steering arm to the spline end of the axle. I think I have this solved as well. I will be using a keyway bored weldable sprocket hub to put on the spline end of the axle. I will grind a 5/16 keyway slot to match the one in the sprocket hub. I will use the factory set screws in the sprocket hub to hold the hub on the axle. I am also considering grinding a groove around the very end of the axle shaft to hold a e-clip, just in case the set screws dont hold or works loose. As a backup plan if the keyways dont hold. I have a bunch of roll pins. I will simply put the hub on the axle and set up the drill to drill each spline into the hub and then drive in a roll pin to act as sprocket teeth. Not precision machine work by any stretch of engineering, but hillbilly enough it will work for what i am trying to do.
   / forgeing splines using a axle and press #39
This thread could use some pics...:D
   / forgeing splines using a axle and press #40
If you have a steady rest you could set the axle flange in the chuck with the carriage all the way out and the steady rest acting a couple inches inward, closer to the chuck. Extend the grinder outward from the tool post to reach the spline end of the axle. Since careful grinding with a disc is low force you should have no problem unless a long extension is necessary.
CHALLENGER MT525B TRACTOR (A59823)
CHALLENGER MT525B...
2007 Ford E350 (A55973)
2007 Ford E350...
2003 IC Corporation 3000IC School Bus (A59230)
2003 IC...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A60429)
2007 CATERPILLAR...
PALLET OF SCRUBBER PODS (A58214)
PALLET OF SCRUBBER...
2005 Peterbilt 387 with Wet Kit (A56438)
2005 Peterbilt 387...
