Fuel Additives for Kubotas
   / Fuel Additives for Kubotas #21
I never used anything regularly, was told I didn't need anything by the dealerships. Once in a while I would get a bottle of PowerService just because, but would forget to put it in most of the time anyway.
I can only say what the service manager explained to me, because of my doubts about adding anything. He told me the tips of the injectors need at least a little lubrication that dry fuel oil don't provide. I didn't ask but I am sure the pump needs lubrication also. I told him I have some PowerService is for water mostly and he told me that just makes it more dry and more harmful.
<snip>
My BIL, my stepson, and I all own post 2009 VW Common Rail Diesels with Bosch Fuel pumps.
My stepsons pump cratered about a year ago, requiring replacement of the entire fuel system, luckily under warranty. Befoe he drove away after the repair they gave him some snake oil.
For decades there have been reasons for additives:as a biocide, to get water out, to prevent freezing. But with the advent of ULSD lubrication has become important for fuel pumps designed for European fuel which has a lower scar rating. Here's a good excerpt:
Insufficient Lubricity:
ULSD fuel lubricity is measured by measuring the scarring caused by impurities in the fuel on metallic fuel system components. The lower the lubricity, the larger the dimensions of the scars. The unit of measure used to measure such scarring is the micron. The scarring potential of fuel is tested using a device called a High Frequency Reciprocating Rig (or "HFRR"). Fresh ULSD contains no additives of any kind, though it may contain contaminates and may vary in lubricity by virtue of variances in the refining process. No station pumps raw diesel. Raw ULSD fuel can range from 900 microns to 600 microns in HFRR rating. When a refinery sells ULSD, the distributor or retailer is required to add lubricity additives sufficient to meet legally specified minimum lubricity standards. In the United States ULSD fuel (Diesel #2) legally must have an HFRR lubricity rating of 520 microns or less. But it frequently it does not meet this standard.
In one test the tester sampled retail diesel fuel from stations in 13 different states. Only 7 retailers met the legal 520 micron or better standard. 6 of the retailers provided fuel ranging from 605 microns to 845 microns(!) in HFRR rating. Yep, it looks like about half the distributors/stations in the country minimally treat or do not treat at all the raw diesel fuel the sell. There's a special place in Diesel **** for such scumbags, but I digress.
So why does the HFRR rating of the fuel matter? Because almost every consumer clean diesel vehicle sold in the United States uses a high pressure fuel pump (HPFP) manufactured by Bosch. Bosch's maximum HFRR rating for its HPFP? 460 microns or less. Houston we have a problem. Though US law permits the peddling of fuel with an HFRR rating of up to 520 microns, and about half the time US retail ULSD fuel fails to meet even this lax standard, the fuel systems in the vehicles into which this gritty fuel is going risk accelerated wear and premature, catastrophic failure of the fuel delivery system including the HPFP and injectors. Easily a $8k to $10k repair bill potential. There's a 60 micron gap between what's legally allowed in the US and what is permitted by the HPFP manufacturer.
Why do vehicle manufacturers sell vehicles in the US that have a HPFP that requires greater lubricity than our fuel provides? Europe. It's always Europe's fault. Europeans buy a lot more diesel consumer vehicles than Americans. In Europe their fuel quality regulations are much, much tighter, the enforcement much more aggressive and the penalties for violation much more severe (you get caught pushing raw diesel in Germany and you'll *wish* they sent you to Diesel ****). As a result Europeans enjoy ULSD fuel with superior lubricity (460 - hey! Just like the Bosch pump!) and Cetane (51 minimum) ratings compared to us, their poorer and more (diesel) ignorant cousins across the pond.
from here
So many modern fuel pumps require more lubricity. This may be accomplished by using biodiesel, but it needs to be done. VW has finally admitted it.
I use Opti-Lube.
   / Fuel Additives for Kubotas #22
Another power service (white bottle) guy here, use year around also.
   / Fuel Additives for Kubotas #23
Yep, blending #1 and #2 will prevent gelling. Just like adding PowerService. Blending is much more expensive. Blending also creates a fuel that produces less power. It's very noticeable in our Road Grader. So we treat rather than blend.
It is even noticeable when the stations switch to the winter blend here in MD. I saw a 3 mpg drop...20%...in my SD. Problem here is just about all if not all of the stations that sell diesel go to the blend I the Winter. Do they up your way as well? I'm guessing if you are buying off road fuel you have the option to get #2.......and I'm sure you don't use that in your truck...
   / Fuel Additives for Kubotas #24
Yep, all stations that sell Diesel use "Winterized" fuel. How they arrive at that point is unknown. And their only concern is that it will go thru the pump nozzle and into your tank. After that, you are on your own.
I use off road in my tractors. The township also uses off road in the Grader. I treat both with Power Service to prevent Gelling.
As someone mentioned earlier, you'll only Gel fuel once. :eek:
   / Fuel Additives for Kubotas #25
Newbury -- You said "So many modern fuel pumps require more lubricity. This may be accomplished by using biodiesel, but it needs to be done. VW has finally admitted it."
Admitted what ? Where did they admit whatever it was -- in print, news article, notice to owners ? We own a VW TDI and have seen no admissions of anything other than outsmarting the EPA. My verb, not theirs.
   / Fuel Additives for Kubotas #26
Yeah, that's why I've never had a fuel gel problem at temps below zero using it. Definitely isn't worth the 4 cents per gallon cost..... :D
How do you know PS is keeping the fuel from gelling? You could be buying a quality winter blend fuel.
What leads you to say that?
I always hear claims like this about addatives but rarely any data behind it.
Deere Dude pretty much summed up why I don't use PS. I used power service as directed in the BX and had the fuel filter ice up twice. Scooby074 on here had problems with PS. If you do some searching you will see a lot of people have had fuel gel with it, some in to real cold temps. When I switched to Stanadyne Lubrictiy formula my problems went away. If you are worried about gelling there are better products than PS.
Very recently I had my fuel pump go out on my truck and had the BIG diesel repair shop change my injectors right away also because in my year of truck injectors were noted to go out at the 150,000 mile mark quite often.
At the cash register I saw probably 100 cases of fuel additive so I asked the question we are contemplating here; what to use?
He said to use to use Standyne Lubricity Formula for my fuel. He said the fuel is so dry now that lubricity helps the injectors last longer. I asked about Power Service in the white bottle because I have a couple bottles. He told me that just makes everything drier and harder on the injectors. It if doing just the opposite of what should be done.
But I theorize that my tractors fuel tank is outside and may get some moisture in so I use Standyne Lubricity Formula for the lubricity formula but may put a little Power Service in for any water. And to change the fuel filters more often, like every 2 oil changes, especially in my truck.
For me the lubricity area is what I would be more concerned with..
I run Stanadyne Lubricty formula.
   / Fuel Additives for Kubotas #27
Is there anything in all this dialog legitimately unique to Kubota or are we just talking diesels in general? Maybe the real distinction (regarding lubricating qualities and costly high pressure injection pumps) is not brand but rather newer tech versus the older tech "simple" diesels.
   / Fuel Additives for Kubotas #28
I'm talking diesels in general.
   / Fuel Additives for Kubotas #29
What did you like better about Howse over PS?
It got proven to me a couple years ago. I used to haul new travel trailers commercially, and one time I was coming out of Indiana and my Powerstroke starting running bad and all the engine lights came on. I had already been running Power Service in my fuel.
Went to a Ford dealer in Coldwater, MI. and they scanned it. Said two injectors were dead but they couldn't get me in. Said I could drive it, but it will be hard on fuel and run rough.
So I stopped at a Flying J, and for whatever reason I wanted to put some more conditioner in. They had no Power Service, so I bought Howes. Put some in, got back on the highway and within a few miles the check engine lights went out and it ran perfect. It actually unstuck those two injectors. So I was sold.
So now I just buy it and haven't had a single fuel related issue in anything from my Kubota to my big truck and equipment. They also make a very good spray lube. I got a sample at a truck show and tried it.
   / Fuel Additives for Kubotas #30
It got proven to me a couple years ago. They had no Power Service, so I bought Howes. Put some in, got back on the highway and within a few miles the check engine lights went out and it ran perfect. It actually unstuck those two injectors. So I was sold....So now I just buy it and haven't had a single fuel related issue in anything from my Kubota to my big truck and equipment.
Understand your datapoint and that would have been positive for anyone. However, let me wonder out loud -- First thought is if an injector really is stuck (or clogged) additive in the fuel cannot get to it since there is no flow through it (unless a couple of injectors were intermittent, sometimes firing as expected and sometimes not.) Maybe when you stopped at the Flying J the heat of the engine got to those injectors, more likely the lines to the injectors, and helped get rid of the gel if it was gelled. Possibly it was not the additive. Those unknowns are why I call additive "tiger repellent" having seen no tigers for a long time. It is hard to be sure and every long-term user builds confidence in a product -- the longer time goes on with no problems the greater likelihood it really is the additive.
2023 WESSEX RMX500 LOT NUMBER 44 (A53084)
2023 WESSEX RMX500...
2014 Toro Workman HD 07369 Utility Cart (A51691)
2014 Toro Workman...
Black Galvanized Steel Fencing Kit (A55758)
Black Galvanized...
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
2020 VOLVO EC35D EXCAVATOR (A52706)
2020 VOLVO EC35D...
CASE TV370B SKID STEER (A52706)
CASE TV370B SKID...
