fuel from grass?
   / fuel from grass? #33
I believe the computer will adjust the flow, especially with OBD III. It's the make up of the gasket and seal material that will render inoperative the non E85 engines.
   / fuel from grass? #34
   / fuel from grass? #35
Based on the fumes I think it was methanol in the older Indy cars. I thought I read that today, because of politics, it is ethanol.
   / fuel from grass? #36
   / fuel from grass? #37
<font color="blue"> I think the Indy 500 cars used to run on straight ethanol.</font>
In the past it was methanol, this year it's a methanol/ethanol blend, next year it's ethanol.
Re: previous post...Not sure what the IRL running ethanol has to do with politics. /forums/images/graemlins/confused.gif
   / fuel from grass? #38
   / fuel from grass? #39
IRL wanted to run the midwest produced alcohol. Maybe PR would be a better term than politics. IRL has taken some press heat for non US drivers.
BTW why do they use alcohol? I've heard it was so pit lane refueling fires could be put out with water. I've also heard it was because alcohol allowed higher compression ratios.
   / fuel from grass? #40
2025 New/Unused 72in Skid Steer Brush Cutter (A51573)
2025 New/Unused...
FORD 555B BACKHOE (A51406)
FORD 555B BACKHOE...
2017 Club Car Carryall 1700 (A51573)
2017 Club Car...
2018 Suzuki KingQuad 750 AXi 4x4 ATV (A51691)
2018 Suzuki...
2010 KMC 3376 Peanut Combine (A53472)
2010 KMC 3376...
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
