fuel from grass?
   / fuel from grass? #33
I believe the computer will adjust the flow, especially with OBD III. It's the make up of the gasket and seal material that will render inoperative the non E85 engines.
   / fuel from grass? #34
   / fuel from grass? #35
Based on the fumes I think it was methanol in the older Indy cars. I thought I read that today, because of politics, it is ethanol.
   / fuel from grass? #36
   / fuel from grass? #37
<font color="blue"> I think the Indy 500 cars used to run on straight ethanol.</font>
In the past it was methanol, this year it's a methanol/ethanol blend, next year it's ethanol.
Re: previous post...Not sure what the IRL running ethanol has to do with politics. /forums/images/graemlins/confused.gif
   / fuel from grass? #38
   / fuel from grass? #39
IRL wanted to run the midwest produced alcohol. Maybe PR would be a better term than politics. IRL has taken some press heat for non US drivers.
BTW why do they use alcohol? I've heard it was so pit lane refueling fires could be put out with water. I've also heard it was because alcohol allowed higher compression ratios.
   / fuel from grass? #40
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
2024 JOHN DEERE 8R 280 LOT IDENTIFIER 8 (A53084)
2024 JOHN DEERE 8R...
UNUSED CFG INDUSTRIAL MX12RX EXCAVATOR (A51247)
UNUSED CFG...
UNUSED AGT TSOCPF48 MAST W/ 48" FORKS (A51248)
UNUSED AGT...
2019 TEREX PHOENIX 2100 TROMMEL SCREEN (A53426)
2019 TEREX PHOENIX...
UNUSED JCT 84" PUSH BLADE (A51248)
UNUSED JCT 84"...
