fuel from grass?
   / fuel from grass? #33
I believe the computer will adjust the flow, especially with OBD III. It's the make up of the gasket and seal material that will render inoperative the non E85 engines.
   / fuel from grass? #34
   / fuel from grass? #35
Based on the fumes I think it was methanol in the older Indy cars. I thought I read that today, because of politics, it is ethanol.
   / fuel from grass? #36
   / fuel from grass? #37
<font color="blue"> I think the Indy 500 cars used to run on straight ethanol.</font>
In the past it was methanol, this year it's a methanol/ethanol blend, next year it's ethanol.
Re: previous post...Not sure what the IRL running ethanol has to do with politics. /forums/images/graemlins/confused.gif
   / fuel from grass? #38
   / fuel from grass? #39
IRL wanted to run the midwest produced alcohol. Maybe PR would be a better term than politics. IRL has taken some press heat for non US drivers.
BTW why do they use alcohol? I've heard it was so pit lane refueling fires could be put out with water. I've also heard it was because alcohol allowed higher compression ratios.
   / fuel from grass? #40
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2017 Ford F-150...
UNUSED FUTURE SB05 HYD BREAKER (A51248)
UNUSED FUTURE SB05...
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
2019 Kubota RTV-X1140 4x4 Utility Cart (A51691)
2019 Kubota...
20' BI-PARTING GATE (A51248)
20' BI-PARTING...
2001 Nissan Frontier Crew Cab Pickup Truck (A51692)
2001 Nissan...
