% Grade vs Degrees
   / % Grade vs Degrees #1
NewToy
Ohio
'05 Farmtrac 270DTC
Anyone know what the difference between % of a grade as opposed to how many degrees the grade is? I always see the signs on the hiway saying 5% grade and it sure seems awfully steep.
Thanks,
John
Thanks,
John
   / % Grade vs Degrees #3
I believe % grade is a measure of the rise to the run or how much the roadway rises compared to the length. If a roadway rose 1' for each 1' of length, that would be 100% grade (or the same as 45°). A 5% grade would rise 1' for each 20' of length or about 2-1/2°. When you are looking into a grade, your perspective is distorted. If you looked at the grade from the side, it would look a lot less imposing.
Disclaimer: There is a good possibility that my explanation is completely bogus, it's just my own understanding or lack of same. /forums/images/graemlins/smirk.gif /forums/images/graemlins/laugh.gif
   / % Grade vs Degrees #4
   / % Grade vs Degrees #5
Percent grade is just the rise over run. A 45 degree slope is 100% as the rise and run are the same. Your 5% grade is 5 feet in 100 which calculates to 2.86 degrees. The formula is Angle = ATAN (Rise/Run).
If you think 5% feels steep, try that 100% grade sometime /forums/images/graemlins/smile.gif
   / % Grade vs Degrees #6
   / % Grade vs Degrees #7
Here is how I figure 5% grade. 5/100=.05. Then take .05 and inverse tan which gives you 2.862405 degrees. Hope this helps.
   / % Grade vs Degrees #8
   / % Grade vs Degrees #9
Here's a LINK to a grade calculator.
   / % Grade vs Degrees #10
   / % Grade vs Degrees #11
Looks to me like everybody got it right, but jinman and RobS figure it the way I would. I'd probably never remember "inverse tan" and Chili's method even though you get the same result. /forums/images/graemlins/laugh.gif
   / % Grade vs Degrees #12
I always see that "5% Grade Ahead" sign going through Virginia at Fancy Gap. That's when they start putting the "Runaway Truck" escape ramps along the road. It seems like it's steeper than that but I guess not.
Thanks fellas,
John
Thanks fellas,
John
   / % Grade vs Degrees #15
I don't remember where "Fancy Gap" is, but I do remember a grade of that much, or more, on I-64, and one of those escape ramps on I-77 in Virginia. But the most deceiving one I've driven on was (best I can remember) about a 6 mile stretch of 12% grade on the north slope haul road in Alaska. They named their slopes and that one was called "Beaver Slide". I have a couple of pictures of a truck, burned completely up, sitting at the bottom of that slope.
   / % Grade vs Degrees #16
   / % Grade vs Degrees #17
Salt River Canyon on U.S. 60 in Arizona carries a 6% grade. I agree it looks much steeper that it measures in degrees. Are there any places with greater that 6% grades on U. S. Highways, excluding dirt roads in the back country? I seem to recollect a 7% grade somewhere in my readings, but don't remember where that was, or if I was just dreaming.
   / % Grade vs Degrees #18
   / % Grade vs Degrees #19
</font><font color="blue" class="small">( Salt River Canyon on U.S. 60 in Arizona carries a 6% grade. I agree it looks much steeper that it measures in degrees. Are there any places with greater that 6% grades on U. S. Highways, excluding dirt roads in the back country? I seem to recollect a 7% grade somewhere in my readings, but don't remember where that was, or if I was just dreaming.
)</font>
6% is the federal limit for interstate highways.
Of course....everything is subject to exception. /forums/images/graemlins/crazy.gif
   / % Grade vs Degrees #20
)</font>
EZ loader trailer (A56857)
EZ loader trailer...
2014 Nissan Rgue SUV (A59231)
2014 Nissan Rgue...
Caterpillar 906M (A53317)
Caterpillar 906M...
WBrock Meyer 2000S 70'x12' 2000 BPH Grain Dryer W/Legs&Mill Discharge Sylo,Controller is included (A57148)
WBrock Meyer 2000S...
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
2022 CAT 289D3 (A60462)
2022 CAT 289D3...
