Grease zerk question (b2620 w/ QA from b3200)
   / Grease zerk question (b2620 w/ QA from b3200) #1
DieselDon
B2620
I have a new b2620 with the quick attach (FEL) from the b3200. It's amazing. There are supposed to be 6 grease points per side on the FEL, but there are only 4 zerks per side due to the QA.
It's obvious (black grease collecting dirt) that the QA has two grease needs on rotating pins, but those pins are attached by bolts. How does one get the grease inside the pivoting area?
   / Grease zerk question (b2620 w/ QA from b3200) #2
You have the wrong pins in the quick attach bracket. You reuse the greaseable pins that were in the bucket on the QA. The solid pins that come with the QA are to go in the top hole of your attachments.
Thanks for the insight. The dealer, during set up, has done a few things wrong but they've more than made up for it.
I'll hunt down the correct pins.
Thanks again
2012 Wagner-Smith T-BWT-4-38-PRC Towable Single Place Reel Carrier-Tensioner (A46683)
2012 Wagner-Smith...
Ingersoll Rand 2545 120 Gallon Air Compressor System (A45336)
Ingersoll Rand...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A45336)
12-Wheel Pneumatic...
Land Pride 510 Hydraulic Skid Steer Breaker (A48561)
Land Pride 510...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A46683)
2015 Freightliner...
2017 Chevrolet Silverado 4x4 2500 HD Crew Cab Pickup Truck (A45336)
2017 Chevrolet...
