Greased all zerks
   / Greased all zerks #11
Glad to know that I'm not the only person who has imagined a grease gun dangling from the zerk. Would that be tractor "bling" or "blah"? :laughing:
That makes a great mental picture. My tractor working with a half dozen grease guns hanging off like ticks on a coon dog.
   / Greased all zerks #12
Worked as a "oiler" on cranes for long enough to know the stuck for life feeling. A good grease gun has the tip that screws left or right to allow for just such a adustment. A good operater can tell if you are doing the job properly just by watching the type grease gun you are using. No one style works for or can reach all the fittings on most cranes, or pieces of equipment. With the price of down time or replacement parts-grease is good.
   / Greased all zerks #13
Grease Gun tips usually unscrew in two pieces....allowing for relaxing internal pressure on grease to allow removal....
I always make sure the tip is only finger tight (between the sections) when greasing that way when one is stuck (because pressure is built-up in fitting) then you can loosen with your fingers.....VIOLA.....Instant Release.....:thumbsup:
   / Greased all zerks #14
Just did mine the other night for the first time. I did find one zerk (on the outrigger foot) that wouldn't take grease and the little bearing was gone. Went and bought a new one, cleaned it up and installed it. The foot was pretty dry and still wouldn't take grease. I hit the whole thing with some WD-40 and used a hammer to tap the shaft back and forth to break the rust loose and viola....she takes grease now. This is a lot of fun. I don't have to be quite as delicate as when working on my motorcycles and cars, and to me, a lot of extra grease flying around just adds to the ambience.
2018 KOMATSU WA200-8 WHEEL LOADER (A60429)
2018 KOMATSU...
UNUSED FUTURE ML32 - 32" MINI HYD MULCHER (A52706)
UNUSED FUTURE ML32...
2000 FORD F550 SUPER DUTY SERVICE TRUCK (A60430)
2000 FORD F550...
3650 (A47477)
3650 (A47477)
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
2014 Lamar Trailer (A55973)
2014 Lamar Trailer...
