Help! Flickering lights/haunted house
   / Help! Flickering lights/haunted house #31
Most likely in the neutral connection some where, either the connection at your box, in the cable, or at the utility's transformer. Note: Your panel neutral bus should be "grounded" to 0 Volts by a connection to your ground rods. This connection should be made at one location only, at the first disconnect point of your service. Typically there is a jumper between the panelboard's neutral bus (white wires) and the ground bus (green wires) in the panel, and the ground bus is connected to a ground rod in earth.
Most likely in the neutral connection some where, either the connection at your box, in the cable, or at the utility's transformer. Note: Your panel neutral bus should be "grounded" to 0 Volts by a connection to your ground rods. This connection should be made at one location only, at the first disconnect point of your service. Typically there is a jumper between the panelboard's neutral bus (white wires) and the ground bus (green wires) in the panel, and the ground bus is connected to a ground rod in earth. <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=357821"/>
One of the first things the electrician tried was adding a new ground.
   / Help! Flickering lights/haunted house #33
i still say that once a temp run is placed above ground all your issues will disappear. Then the only thing left to do i start digging a new one. And DONT agree to direct burial. If they had pipe the 1st time this wouldnt even be an issue.
yep. I'm with you.
   / Help! Flickering lights/haunted house #35
Around here power company will no longer use direct burial. But you have to provide the conduit.
   / Help! Flickering lights/haunted house #36
What size conduit are you looking at?
I know Comcast wanted a 2" conduit just to run a line to a single family home.
Actually it's all on me. That's their policy for buried service lines. Bummer.
   / Help! Flickering lights/haunted house #38
well that sucks. here, and in all the states I've worked at in the past, the utility companies have been responsible for all lines (buried & overhead) that go from the power generating system to the METER. Anything after the meter was the customers responsibility.
   / Help! Flickering lights/haunted house #39
Sounds like you may have it narrowed down, another way to check the panel box is to run your appliances and try to see a hot spot in the panel with a FLIR camera. A laser thermometer will work as well. You could also lift both ends of the service feed and megger it...
Temporary cable fixed it. Of course the utility company guy didn't come out until 230 on a Friday so they'll have to come back next week to fix it. Wait wait wait.
2015 Ford F-150 Ext. Cab Pickup Truck (A55788)
2015 Ford F-150...
John Deere 4 Row Cornplanter (A50775)
John Deere 4 Row...
Belarus 250AS Tractor w/Loader (RUNS)(DOES NOT MOVE) (A50775)
Belarus 250AS...
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55788)
2022 Chevrolet...
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A54757)
UNUSED WOLVERINE...
40' High Cube Multi Door Shipping Container (A53316)
40' High Cube...
