Help with top link adjustment for rotary cutter.
   / Help with top link adjustment for rotary cutter. #161
All you need to completely float a deck is three points of ground contact. Heck, you could drag it from the hitch if you had front gauge wheels. What you will have is a rough cut finish mower.
I think part of the character of a brush hog cut field is the slight variations. Digging in to the dirt should really be avoided though.
   / Help with top link adjustment for rotary cutter. #162
   / Help with top link adjustment for rotary cutter. #163
My situation is the opposite of Beenthere's pic. I have a ditch bank I'd like to keep free of multiflora, but the ditch is alongside a 60 mph road and near a blind corner. If I can figure out a way to lower the mower from the top so it will cut at about a 45 degree down angle from a level tractor, I'd be sitting pretty. I may need to get a new PTO shaft, but do you guys have any ideas about how to rig things to allow the mower to hang down over an edge for mowing yet still be able to pick it up to at least level to move over 4 feet and do it again? No, I don't have T n T, but I do have a set of rear remotes.
   / Help with top link adjustment for rotary cutter. #164
   / Help with top link adjustment for rotary cutter. #165
</font><font color="blue" class="small">( I may need to get a new PTO shaft, but do you guys have any ideas about how to rig things to allow the mower to hang down over an edge for mowing yet still be able to pick it up to at least level to move over 4 feet and do it again? )</font>
I've have set mine, at times, to allow the rear to hang way down by lengthening the top link to the extreme. I was still able to pick it up enough, with the tailwheel still touching, to move over and back into the material. I nearly never have had to pick it up all the way, just enough to let it move.
I back into my ditches with the mower up some, and as it goes in, I start lowering it to cut. Works great for me.
John
   / Help with top link adjustment for rotary cutter. #166
John
   / Help with top link adjustment for rotary cutter. #167
<font color="blue"> You've got a crazy twist on your belt. </font>
Highbeam,
That is common for that era Woods RFM. I have a RM59. It is a tank, but what really gets twisted is your brain as you try to put that belt on! /forums/images/graemlins/confused.gif
Gary
   / Help with top link adjustment for rotary cutter. #168
Highbeam,
Gary
   / Help with top link adjustment for rotary cutter. #169
djradz
In your pic posted, its a good one of the check chains for height, but I don't see any allowance or room for the rear of the deck to raise without bending something with that top link being so long.
A good place for a chain instead of the toplink. /forums/images/graemlins/wink.gif
   / Help with top link adjustment for rotary cutter. #170
djradz
   / Help with top link adjustment for rotary cutter. #171
Adding a long hyd cylinder to the deck in place of either my chains or the straps would allow you to droop the rear of the deck further and still pick it up. With your rear remotes, you could then position the control valve in float to allow the rear of the deck to follow the ground. I'd think, anyway.
Can't think of anything else that would work on the negative slope. Gets hairy to back up to a slope like that. /forums/images/graemlins/shocked.gif /forums/images/graemlins/wink.gif
   / Help with top link adjustment for rotary cutter. #172
   / Help with top link adjustment for rotary cutter. #173
</font><font color="blue" class="small">( All you need to completely float a deck is three points of ground contact. )</font>
Joe, I've looked at this picture several times now, and I finally decided that I really wouldn't want to modify my hog with those front gauge wheels. I wouldn't be able to drop the front all the way down as I often need/want to do. When I'm cutting a ditch bank, back down into it, I like to then drop the mower all the way down and really cut thing close. Those wheels would get in the way of that for me. I can think of a few other situations where I would want to lower it all the way down.
John
   / Help with top link adjustment for rotary cutter. #174
John
   / Help with top link adjustment for rotary cutter. #175
That mower was not mine but an example of a poor top link structure design that I needed to remove for another project. The photo shows that front gauge wheels can be done and one way to do it. I don't even use chain guards on my hog. I like the implementation of check chains on that NH though.
With position control on the 3ph, the only reason I can see for check chains is so that you could raise the hog off of a surprise stump or rock and then put it back down to the same height without depending on that handy set screw.
   / Help with top link adjustment for rotary cutter. #176
   / Help with top link adjustment for rotary cutter. #177
</font><font color="blue" class="small">( With position control on the 3ph, the only reason I can see for check chains is so that you could raise the hog off of a surprise stump or rock and then put it back down to the same height without depending on that handy set screw.)</font>
Yeah, the chains are really handy for older style hitches without position control and those that have become droopers and don't stay up well.
With position control, I just set my hog to the number on the lever guide that I know gives me the cut I want for a particular property, and if I hit something, I raise it quickly and then put it back to that number. Works great for me.
John
   / Help with top link adjustment for rotary cutter. #178
John
   / Help with top link adjustment for rotary cutter. #179
"With position control on the 3ph, the only reason I can see for check chains is so that you could raise the hog off of a surprise stump or rock and then put it back down to the same height without depending on that handy set screw."
All the check chains do is save wear and tear on the 3ph. The chains take the load rather than the hydraulics, a pretty good $35 investment, I think.
   / Help with top link adjustment for rotary cutter. #180
Husqarvana Riding Mower (A56857)
Husqarvana Riding...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A59231)
2014 Glasstream...
SHOP BUILT TOOL TRAILER (A58214)
SHOP BUILT TOOL...
2017 GENIE GTH844 TELESCOPIC FORKLIFT (A60429)
2017 GENIE GTH844...
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
43023 (A59228)
43023 (A59228)
