Help with top link adjustment for rotary cutter.
   / Help with top link adjustment for rotary cutter. #171
Adding a long hyd cylinder to the deck in place of either my chains or the straps would allow you to droop the rear of the deck further and still pick it up. With your rear remotes, you could then position the control valve in float to allow the rear of the deck to follow the ground. I'd think, anyway.
Can't think of anything else that would work on the negative slope. Gets hairy to back up to a slope like that. /forums/images/graemlins/shocked.gif /forums/images/graemlins/wink.gif
   / Help with top link adjustment for rotary cutter. #172
   / Help with top link adjustment for rotary cutter. #173
</font><font color="blue" class="small">( All you need to completely float a deck is three points of ground contact. )</font>
Joe, I've looked at this picture several times now, and I finally decided that I really wouldn't want to modify my hog with those front gauge wheels. I wouldn't be able to drop the front all the way down as I often need/want to do. When I'm cutting a ditch bank, back down into it, I like to then drop the mower all the way down and really cut thing close. Those wheels would get in the way of that for me. I can think of a few other situations where I would want to lower it all the way down.
John
   / Help with top link adjustment for rotary cutter. #174
John
   / Help with top link adjustment for rotary cutter. #175
That mower was not mine but an example of a poor top link structure design that I needed to remove for another project. The photo shows that front gauge wheels can be done and one way to do it. I don't even use chain guards on my hog. I like the implementation of check chains on that NH though.
With position control on the 3ph, the only reason I can see for check chains is so that you could raise the hog off of a surprise stump or rock and then put it back down to the same height without depending on that handy set screw.
   / Help with top link adjustment for rotary cutter. #176
   / Help with top link adjustment for rotary cutter. #177
</font><font color="blue" class="small">( With position control on the 3ph, the only reason I can see for check chains is so that you could raise the hog off of a surprise stump or rock and then put it back down to the same height without depending on that handy set screw.)</font>
Yeah, the chains are really handy for older style hitches without position control and those that have become droopers and don't stay up well.
With position control, I just set my hog to the number on the lever guide that I know gives me the cut I want for a particular property, and if I hit something, I raise it quickly and then put it back to that number. Works great for me.
John
   / Help with top link adjustment for rotary cutter. #178
John
   / Help with top link adjustment for rotary cutter. #179
"With position control on the 3ph, the only reason I can see for check chains is so that you could raise the hog off of a surprise stump or rock and then put it back down to the same height without depending on that handy set screw."
All the check chains do is save wear and tear on the 3ph. The chains take the load rather than the hydraulics, a pretty good $35 investment, I think.
   / Help with top link adjustment for rotary cutter. #180
2016 Gravely Pro-Turn 260 60in Zero Turn Mower (A48082)
2016 Gravely...
1999 FONTAINE 48X102 FLATBED TRAILER (A51222)
1999 FONTAINE...
1994 Thomas Built SAF-T-LINER (LOW MILES, CUMMINS, ALLISON) (A52128)
1994 Thomas Built...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2008 Genie ManLift (A50322)
2008 Genie ManLift...
2014 Caterpillar 257D Compact Track Loader Skid Steer (A50322)
2014 Caterpillar...
