Help! Woven wire fence question
   / Help! Woven wire fence question #11
Wow Bird, I guess that proves what a great board this is. A lot of peoples experiences all in one place at your fingertips!
I can't imagine that happening here but I've been wrong before.
I have a pole barn construction book that rates clay soil as "poor to very poor" for stability. They recomend backfilling with a mixture of sand and gravel.
Kevin
   / Help! Woven wire fence question #12
Right on with the pea stone! I put up a pole barn last year in clay, with water in the holes and put pea stone under and around the poles and have had no problems. Back fill all my fencing with it, faster and no blisters from tamping. bcs /forums/images/graemlins/grin.gif
   / Help! Woven wire fence question #13
I don't want to step on this topic but we seem to have the stretching process covered and a bunch of experienced people here. We just bought 32 acres that I will want to fence. It will not be to keep animals in but more to discourage others from crossing the line. What would you consider the most reasonable type of fence to use both for price and installation? Do any of you know any sites that discuss fence building?
MarkV
Thanks for the great advice! I live over near Downs in McLean county, but I'm an Illini through and through.
I had no idea putting up a fence like this would be such a big deal, with the stretching and all. It seems like a lot of work just to keep our dogs out of the road and the creek across the way, but I'd rather do it right than not at all! Thank God for TBN!
   / Help! Woven wire fence question #15
NO fence will keep folks out if they want to come in, but in my experience, if you just want to show the property line, three or four strands of barbed wire. I think it is definatley the cheapest.
   / Help! Woven wire fence question #16
The primary use of our fence is to keep the dogs in. The tough old yeller dog ignores barbed wire and goes through between the strands, so we went with hog wire (goat wire, horse wire, all the same stuff as far as I can tell). The other dog is an adopted greyhound; if she gets out she probably couldn't find her way home, but on the other hand, a piece of dental floss would probably keep her timid soul from crossing.
The second use was to keep the 4-wheelers off the property until we started building; they were starting to tear the place up before we bought it. I didn't have the tractor yet, so I hired it done right after closing. Paid about $1.25/foot installed, plus a little more to clear the fence line, which I understand was a bargain, but it was a fellow who wanted to keep his crew busy until their busy season started. Had a little more than 1,600 feet installed.
I didn't have a gate installed (had access through my daughter's land), but now I'm going back and set up a recessed entry area and gate. I watched the guys do it, and I can handle it, now. They used the same stretching, bracing and stapling described above. I have to install some new corner H-braces right next to existing fence and secure the fence before cutting the hole and removing the small posts, otherwise it might go wild if I tried to cut it, it's stretched so tight.
   / Help! Woven wire fence question #17
Ya Cindi, I agree that no fence will keep people out and I should have worded it different. Around here though there seems to be a degree of respect when it comes to crossing a fence where a posted sign is something to shoot at. Now the same people will not hesitate to throw their trash out of the car window or take a bat to your mailbox but crossing a fence seems to be different. /forums/images/graemlins/mad.gif Guess it gets down to my father-in-laws thinking "good fences make for good neighbors".
MarkV
   / Help! Woven wire fence question #18
Don...we have one of those timid greyhounds too. He's actually a mix, but he's strung tight as a piano wire and smart!
Really good dog. Like your dog, I think a cob web fence would hold him if you showed him that it was meant to be a fence.
Mark, I realize that, I knew what you meant. I don't know what possessed me to say that other than the fact that we've had a few fence climbers around here. Grrrr. There is always that element of people who will crawl over and under barbed wire and then say...'where? where was the property line. I didn't see it!'
We've had our share of mailbox baseball around here too. Ours is in the middle of a row of five, so we usually don't get hit, but the two on the end....poor things.
   / Help! Woven wire fence question #19
Your easiest and cheapest is going to be high tensile fence. I'd put up 5 or 6 strands and electrify one or two of the strands. It won't take long for people to get the hint. If you don't want to do that I would do woven wire with two strands of smooth wire on top.
I wouldn't do barb wire if I was you. If you ever do want to sell it or get some horses or such barb wire can make for some terrible cuts. If you're going to the expense of doing 32 acres you might as well make it so that it can be used for anything in my opinion. Plus a bad cut is also alot harder to heal than a good shock. /forums/images/graemlins/wink.gif
KUBOTA M125X TRACTOR (A60430)
KUBOTA M125X...
2019 Dorsey DF40 40ft. 40 Ton T/A Drop Deck Flatbed Trailer (A60460)
2019 Dorsey DF40...
2014 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A60460)
2014 Chevrolet...
CAT D6T LGP DOZER (A58214)
CAT D6T LGP DOZER...
20.7kW Aptos 440W w/ IQ8PLUS Enphase Microinverter Solar System (A59228)
20.7kW Aptos 440W...
32in. Tilting Bucket Mini Excavator Attachment (A59228)
32in. Tilting...
