Homemade Pool Heater
   / Homemade Pool Heater #31
A neighbor of mine put up a above ground pool a few weeks ago and when I was preparing the site for him with my tractor I came up with the idea of putting 3/4" pex in a continuous loop on top of the soil prior to putting the sand down. He runs it off his wood burning outside boiler. When the pool was filled the water was 68 deg and he brought the temp up to 86 deg in 2 days. We were both really impressed. Works alot like radiant floor heat and the sand really holds the heat well and transfers it well. Anyone who has ever walked on the beach in Florida.
Chris
That would work, unfortunatly he is also pumping a lot of heat into the ground. Thermal transfer is always from warm to cold, and the earth below and around the pipes is always going to be cooler than the pool above. Foam sheets under the pipes would make it a lot more effective by lessening the path to the earth heat sink and forcing more heat toward the pool.
Insulation makes a big difference. We switched to a new above ground pool this year. We had one of the 12' quickset pools with the inflatable collar(big bag of water) and I have a sandy circle I prepared to set it up on. Well that pool had come collar issues that I couldn't resolve so we got a new pool with a frame. Didn't want to waste the prepped water in the old pool so I set the new one up right next to the old on an unimproved surface(grass). I was worried about the bottom, so I layed out some 1" thick white styrofoam sheets that I had in my barn(six 4' x 8' sheets). This pool is the same diameter and nearly twice as deep(2200 gallons). I have a 4'X10' poly solar collector I float on top of the pool to add some heat(pump pushes water thru small tubes). This is the same heater I used on the old pool to add heat during sunny days. I am also using a clear sheet of visqueen layed out on the waters surface to control evaporation, the same as I did on the old pool. I was very pleasantly surprised that this new pool has easilly been running 10-12F warmer than the old pool ever did. I kan't hardly keep the grandkids out of it as it is warm enough for them to stay a very long time. I think this is mainly due to the foam underneath. It also makes a real nice soft bottom...
In my opinion, the only cost effective way to heat a pool is with solar heat. I just got the material for an inexpensive solar experiment that will set on my roof. Well inexpensive because I already have the pump to be able to pump water that high. It will have about 120 SQ/FT of collector surface, so we will see if that will extend our pool season a little bit.
Wood heat will work, and that same 50# of wood over an 8 hour period would raise my pool temp more than a 5K gallon pool, but that is still a lot of wood and a lot of work to prep and keep it fired and heating properly. I think a wood fired hot tub would be a lot more practical:) With good boiler efficiency, It would take about 18# of wood to get a 250 gallon hot tub from 40F to 100F A 50KBTU pellet fired boiler would do that in about 2.5 hours, and be fire and forget. Flip a switch when I get home from work, and it is ready to soak by the time dinner is done:)
   / Homemade Pool Heater #33
I have a 18 x 36 in-ground pool, 22,000 gallons. I built a small barrel type wood heater out of stainless steel. It is about 24" long and 18" diameter. It is double walled around the length so the entire circumference is a water jacket. One end is closed with a flue outlet and the front end is the door. It is fed from the bottom with a garden hose and the water outlet is on top. It works OK but it is too small for this much water. I just can't put enough wood through it. One degree would take about 176,000 BTU at 100% efficiency.
A co-worker who has a 20 x 40, 30,000 gallons, came up with a wood fired setup that can raise 60 gallons per minute 10 degrees or more. I am using this method now too. He got a heavy galvanized steam radiator about 20" square and 3" thick. It has 2" fittings on each end. It is fed from 1 1/2" lines from the pool pump. Thats how he gets the 60 gpm flow. It is laid flat in an insulated fire box and a fire is built under it. A small blower is used for combustion air. Without the insulation the 1/4" sides get red hot. With the blower, he is putting a lot of wood through it. I'll try to get some pics next time I get mine going. I'm near Pittsburgh, PA and this has been one of the worst summers for swimming that I can remember.
Global warming my *****.
Andy
   / Homemade Pool Heater #34
I think we need to ask Al Gore how he heats his pool(s). :D :D
Wedge
   / Homemade Pool Heater #35
Andy
Wow, that is 288,000 BTU/HR at 100% efficiency. That would be 36LB of wood per hour at 100% efficiency. At 85% efficiency it would be around 42LB of wood/HR...
   / Homemade Pool Heater #36
My pool is 18x33 above ground. I have a clear solar cover for it, some type of cover is a must this year. Last year was actually worse hear in NH. I also have 2 - 4x10 foot solar panels that came off a house, I divert some water from the pump through them. These help assuming we have sun. It did get up to 85F one day but I wasn't home to swim it in. Then we had a couple inches of rain. I guess on the bright side, I haven't had to add any water to it. I have yet to have algae since going to liquid chlorine, just keep it close to 2PPM of Cl and the water is clear as can be.
   / Homemade Pool Heater #38
A few years ago, when we had a 12x24 above ground, I had to add cold water and leave the bubble wrap off it. This year I'm using many $$$ with a gas heater for the in ground. I don't like to look at my LP bill.
It has not been a good year in NH.
Frank
   / Homemade Pool Heater #39
I did something like this a few years ago for our camper. I made a small one to sit on the stove and the 12vdc water pump pushes thru enough water to heat it. Sure beats having to find and install a h2o heater in a camper we only use a few times a year.
1979 Ford F-100 Ranger Pickup Truck (A59230)
1979 Ford F-100...
2009 Honda Odyssey Van (A55758)
2009 Honda Odyssey...
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
2844 (A58376)
2844 (A58376)
KBH Tender Trailer (A56438)
KBH Tender Trailer...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
