Hope that you never see your HST like this
/ Hope that you never see your HST like this #1
dannydan3
HST replaced for $1700, and just for fun, I had them return the old parts (minus the case which was also unrepairable)
The second pic is the scoring damage that the mechanic said stopped the fluid feom flowing through. He said it was crud in the fluid.
Where it came from is a mystery, I was always on top of maintenance, even changed the fluid after 3 original hours to get the initial break in metal shavings out. Cheap fluid and hard use most likely the culprits I guess.
Needless to say, it's only HDT from here out.
/ Hope that you never see your HST like this #2
I'm inclined to believe that trying to make it run with no fluid is the cause of the scouring that created the eventual complete failure. Tractors are made to work and a lot of us here have put a lot of hard hours without failure, your damage just looks to me like metal to metal damage.
/ Hope that you never see your HST like this #3
Agree w/ Milkman. You can't run a machine without lubrication, period. Just my opinion, cheaper oil and hard use combined with regular maintenance may only account for shorted service life and/or decreased functionality, not complete self-destruction. I'm still in amazement that that repair was so cheap.
/ Hope that you never see your HST like this #4
A lifetime ago, I attended a week long hydraulics school in Detroit. We worked with the HST type units, but larger for ag applications.
One of the lab sessions, we had a variable speed pump/motor that had the ability to starve oil going into the unit. As it was up to speed running normally, you restricted the oil flow going in with a valve. It grew louder and louder, eventually hammering like crazy.
When we disassembled it, you could see the pitting damage. The instructors said it was caused by high pressure AIR detonating on the metal.
It doesn't take much of that to mess up a transmission. Then all the debris is in the system floating around causing more damage.
ron
Probably, since I had no idea that the machine had lost all of it's fluid until I looked back and saw the puddle in the lawn.
Grass still won't grow there.
I was also suprised that it was so cheap, I was ready to sell it to the dealer "as is" if it was as I originally expected - I thought around $4000 (I was extremely nervous as one would expect)
/ Hope that you never see your HST like this #6
That would be cavitation damage... pumps that starve for oil are prone to it.. the vapor pressure of the oil is lowered allowing gas pockets to form which then implode
I have to agree with the others.. this looks like a lack of lube.. not a hard work / wrong lube issue.
I'd wager that jiffy store 30w engine oil would have produced better results than running low on the correct lube.. etc. IE any oil is better than no oil..
Soundguy
ron
/ Hope that you never see your HST like this #7
Metal to metal, under load, and or cavitation doesn't take long to eat deep into a checkbook.
As for the oil patch... you can mitigate it somewhat with a surfactant.. nothing too alkali though... Just pour or sprinkle in the area.. wet.. rake in with a garden rake.. soak with water.. and then let nature start doing it's work..
Conversly.. you can excavate it and put it in an old 55g drum and burn it off and then replace...
Soundguy
/ Hope that you never see your HST like this #8
My HST failed after 203 hours on mg GR2100. I changed the trans fluid at 50 and 175 hours. Used Super UDT and Kubota filter. Noticed sand looking residue on the suction screen along with metal shavings @ 50 hours. Kubota did not seem concerned. Then @175 hours another fluid change more residue and large pieces of metal. The the cooling fan fastners vibrated loose and the fan came off. Within another few days the tranmission failed. Went to dealer Sept 18, still there its Oct 19. Just got all the parts in yesterday. No complete replacement of trans, they are rebuiulding it. Luckly it made it under warranty by a couple of weeks. Now the warranty reapir is only covered for 90 days. Hope its not a design defect and I have another reoccurence. No assistance from Kubota Credit as they still want my monthly payment. I will never buy or recommend Orange ever again.
Tony
/ Hope that you never see your HST like this #9
Acolar, I know your upset! As would any TBN'er!
Nobody makes any piece of equipment thats a 100% perfect ie "The Titanic."
As far as Kubota Credit wanting payment while in the shop, do you think J.Deere credit/New Holland/ G.E.Credit would have been any different?
Your newly rebuilt trans will be fine,
All I'm saying is life's too short to sweat the small stuff!
You want to worry about something......close your eyes and when open them imagine being an POW in Iraq!
Feel Better!
Live Well!!
Die Strong!!
Frank
/ Hope that you never see your HST like this #10
I dread to think what the inside of my HST looks like. The screens were jammed behind the loader and backhoe subframes and I suspect they were never removed and cleaned since new in about the mid 80's. Not long after I bought it (a couple of years ago) it came to a total stop. Advice here on TBN correctly directed me to the probable cause. I unbolted the BH subframe, removed and cleaned the screen and replaced the oil. I was back in business very cheaply. I was very lucky. (For once!)
/ Hope that you never see your HST like this #11
Tony, one thing important to remember is that your consumer warranty is by Federal Law automatically extended by the number of days your tractor is out of service and in the shop for a warranty repair.
I'm a State Certified Consumer Arbitrator and often amazed the public is not aware of this.
For more info... the two common references are... Magnuson Moss Warranty Act and the Song Beverly Act.
The thinking at the time these consumer protection laws were implemented was fairness... in that it is only fair NOT to count the time your item is out of service due to a warranty repair.
Keep in mind that most consumer protection laws do not apply to business use.
/ Hope that you never see your HST like this #12
Ultrarunner,
Thanks for taking time to post and comment on the warranty extensions. I tried googling the Magnuson Moss Warranty Act but did not get to the reference you mentioned. Now that you clued me I will re-review and also look at the other Song Beverly Act. My machine is for residential/homeowner use and I was exteremenly surprised at the low hours in service failure. As an arbitrator and having more experience in these matter than I how would you envission the 90 day warranty on the repair running with the extension of the time the unit was down (now 33 days and still counting). For example if my unit was down and out of possession for a warranty repair for one month and my base warranty expires during the time the unit is down for repair do the two Acts you referenced extend my base warranty for one month and then the 90 day repair warranty timing start?
Regardless of the outcome , I really appreciate your sharing the warranty extension fact with me!
Thanks
Tony
/ Hope that you never see your HST like this #13
It was my understanding that Kubota has extended the warranty on the GR's rears due to rear end problems. That is part of the reason for the GR2110.
/ Hope that you never see your HST like this #14
What caused the fluid leak?
/ Hope that you never see your HST like this #15
I've received a couple of PM's for more info.
For those interested, here is more info on Consumer rights regarding Warranty Issues. The operative word is "Consumer" Unfortunately, many Consumer Protection Laws do not apply to business applications.
CALIFORNIA LAW
In my Opinion, the most important Warranty Statute in California is "Song-Beverly Consumer Warranty Act." California CIVIL CODE SECTION 1790-1790.4
CA Codes (civ:1792-1795.7)
This is what Song-Beverly states regarding warranty extensions for the time your item is out of service due to a warranty repair.
"A buyer of this product in California has the right to have this product serviced or repaired during the warranty period. The warranty period will be extended for the number of whole days that the product has been out of the buyer's hands for warranty repairs. If a defect exists within the warranty period, the warranty will not expire until the defect has been fixed."
FEDERAL LAW
The Magnuson-Moss Warranty Act is the federal law that governs consumer product warranties. Passed by Congress in 1975, the Act requires manufacturers and sellers of consumer products to provide consumers with detailed information about warranty coverage. In addition, it affects both the rights of consumers and the obligations of warrantors under written warranties and corresponding Federal Law
A Businessperson's Guide to Federal Warranty Law
/ Hope that you never see your HST like this #16
ultrarunner said:
This is what Song-Beverly states .... If a defect exists within the warranty period, the warranty will not expire until the defect has been fixed."
If it fails yet again AFTER the warranty has expired, is it arguable that the defect was never fixed?
/ Hope that you never see your HST like this #17
Wow, Those Balls (in the bearings) are Blue!
I bet what little oil was in there smelled Funky!
/ Hope that you never see your HST like this #18
Actually, the $1700 was probably mostly labor. DannyDan3, can you let us know the breakdown between labor and parts?
By the way, the pictures are basically everything that is inside the HST. That's it. Dead simple and when lubricated very reliable. But, accidents happen and sloppy assembly happens.
jb
/ Hope that you never see your HST like this #19
Yes, in California there are cases where subsequent failure or repeated failure continues after the "warranty" period. Enough failures that substantially effect use, value or safety often result in recalls, repair campaigns and manufacturers silent warranties.
The Act contains an entire section on definitions that are helpful in determining what is and is not covered.
California also has a "Lemon Law" which is quite effective in addressing consumer disputes on new motor vehicles.
The Lemon Law allows Arbitrators to make decisions ranging from No Award to Vehicle Replacement, Mandatory Vehicle Buy Back with deduction for use or the opportunity for the manufacturer to have one last opportunity to effect repair.
Without straying to much further from the original topic... the three issues that I see manufacturers raise the most in defense are:
Improper Maintenance... Being able to document maintenance is important
Improper Use... Using equipment in a manner other than it was designed for.
Damage... The equipment suffered damage... anything from fire, flood, collision, etc.
/ Hope that you never see your HST like this #20
Is that blue thing in the open passage, part of a gasket? Was it there when they took it apart or just get tossed in the box with the other parts?
Lee
FORD 545D TRACTOR (A60430)
FORD 545D TRACTOR...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A60432)
UNUSED RAYTREE...
(10) UNUSED 2.5" RATCHET STRAPS (A60430)
(10) UNUSED 2.5"...
2018 Ford Escape 4WD SUV (A59231)
2018 Ford Escape...
TANK MANIFOLD (A58214)
