How big of a disk setup for a BX24?
   / How big of a disk setup for a BX24? #1
fishpick
Platinum Member
The part of NY with high taxes
L4760 & BX24
What's the biggest disk setup out there for a BX24? I know the rule of thumb for ground engagement is the width of the rear... but a disk is a little different beast and can go bigger...
Anyone running a 5' setup in sandy soil with some rocks? What about a 6' setup?
Whatca got? This would be ground already turned with a plow...
   / How big of a disk setup for a BX24? #2
Two concerns I would have are the weight and maybe the bumpiness. A harrow doesn't really create much resistance. I don't think your BX would have any trouble pulling a 6' harrow through the soil. I have a 6' harrow I use on a larger tractor that I think weighs about 500 lbs. We have sandy soil, but it's pretty rough going when smoothing it out after it's been plowed. I use an old 45 hp ford for the job. I wonder if you would do a lot of bottoming out on a BX.
It really depends on the conditions. If you're plowing soil that has established grass in it, you're going to end up with big clumps after plowing that I don't think a BX could handle driving through. If it doesn't have grass or thick weeds and it's sandy you might be able to get away with just harrowing and skip the plowing.
I use my BX 2350 to cultivate between the rows in a 2 acre garden and I came very close to buying a 4 foot harrow for the job. Instead I bought a cultivator with Danish tines. It has worked so well that I do not think I'll need to plow next year, just harrow, which a lot of ag people are in favor of because it doesn't dig up deeply buried weed and grass seeds.
The land is a 5-6 year neglected hay/soybean field... (I put both because I don't know what it was when abandoned)...
There will be lots of grass clumps - no doubt... But I have worked areas similar to this in years past with an old Wheelhorse - a 1 bottom - and a drag behind cultivator - and had good results.
I'm just wondering how big of a disk the BX can handle... bottoming out on sod clumps is nothing.
Cool video - but how many axles / transmissions / drive train anything have you tore out of that poor BX? Those tires in their setup are CRAZY!
That said - that's a good sized disk setup you have there.
   / How big of a disk setup for a BX24? #6
There is also a video of the Landpride 05 series disc in operation at their website........ on a BX.
   / How big of a disk setup for a BX24? #7
What model Wheel Horse?
RayCo - An old 16 horse Kohler under the hood I think...
Man - does nobody run disks behind their BX24?
   / How big of a disk setup for a BX24? #9
I guess tillers are in favor these days, especially with the smaller tractors, but there are people that use discs with good results. Do a search on posts by Milkman, and you may find something. I would think that the 4', and 5' discs would work fine. Landpride has a video showing their 05 series being used on a BX. Hmm, maybe I can find a picture of Milkman's setup.... Yes, I found a couple. Sure looks bigger than 4' to me! :D
   / How big of a disk setup for a BX24? #10
The soil is the biggest key. In Chucks pictures I only see the disk going in the ground a few inches deep. The soil doesn't look that sandy. I just ran the disk over my garden which is a true sandy loam(locals call it sugar sand). No rocks. With my lightweight L and a light duty 5' disk, after a couple passes the ground is very soft and the disk will sink to their axles...thus burying my tractor. 4wd won't do much either. This same garden would bury a 10' disk on a 55hp tractor. Not sure how the rocks would react to all this.
Now I have used my 5' disk on some harder clay type soil, in that stuff I could only get down 2-4 inches(with a weight on the back). No problem pulling it in that stuff.
First pick is the sand, second is the clay. Good Luck, Rob
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A55745)
2020 INTERNATIONAL...
Enclosed Service Truck (A55788)
Enclosed Service...
Kubota Snow plow with subframe
Kubota Snow plow...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A56438)
Neckover GL24-2-7K...
