How Many Hours on Your BX?
   / How Many Hours on Your BX? #11
Purchased my BX in June of 2011. I have 180 hours on it. Had to tighten the radiator clamp once. I use it mainly for snow plowing and hauling firewood. I'm extremely happy with my Kubota and I plan to do a major service this fall. Thanks to this forum and Paul Short, I can do most of it myself.
   / How Many Hours on Your BX? #12
My 23 had 1800 hours when I took out the pinion shaft and case I got rid of it bought bigger
   / How Many Hours on Your BX? #13
2010 BX1860, 470 hours, used 4 seasons out of the year for all sorts of activities including mowing, tree pulling, aerating, PTO generating, snow moving, FEL'ing, and so on. No inherent product quality issues to date. I self-inflicted a few problems, for example just about tearing off the left side ROPS-mounted blinker/indicator light assembly and breaking one of the lenses in the process. This was due to a tree and associated branch that came at me out of nowhere.
ps
I would be interested to know whether folks having issues with rubber boots (etc) store their tractor indoors or outdoors. Mine is stored indoors (in a non-climate controlled environment, but out of the sunlight).
Now that I think of it, my boots wore out, too.
   / How Many Hours on Your BX? #14
I bought my BX2360 in 2011 it now has 96 hours on it. No problems but it has very little time on it. I bought it because I wanted something small with a FEL and to mow with. I thought my Kubota G1900 would have given me problems by now but it is running as good as the day I bought it. So I haven't ever even put the MMM on it yet. The mowed deck in covered up and in the garage.
   / How Many Hours on Your BX? #15
I traded my 2000 BX2200 in 2009 with 1257 hours on it. It had a FEL and MMM, with probably 1,000 hours mowing time. I had to replace all 4 power steering hoses, the air cleaner bracket, and the fuel gauge sender-all common problems. Changed the front tires at about 1,000 hours-weather checked. Never changed the battery.
Will
   / How Many Hours on Your BX? #16
I've had a few though over 3500 hours. Daily use in dairy barns.
Now that is some serious Hrs.
I can't say I ever recall anyone talking about a BX "wearing" out.....
   / How Many Hours on Your BX? #17
I finally had to split my 1984 L2550DT in half to do the clutch. 5,540 hours on this little guy. Engine runs great just lost the rear crank seal and clutch failed due to oil.
Oil and filter every 100 hours. Hydraulic fluid and filter every 300 hours and frequent grease. Maintenance, maintenance, maintenance. Oil is cheaper than metal. Shoved a 1/2 inch stick through the radiator core 21 years ago and has never developed a leak.
This is one tough little guy.
   / How Many Hours on Your BX? #18
ps
same. always indoors but not climate-controlled. similar environment as my cars, some of which are older, see much more use, and have all the boots intact.
it's clearly a supplier a material failure.
   / How Many Hours on Your BX? #19
2006 1200 hours. Have slowed down the last 5 years...Most of work accomplished! Main transmission input leak, front steering pivot leak, FEL loader arms and mounts WORN and had to replace.
   / How Many Hours on Your BX? #20
2004 BX2230 that I bought used in 2011 (off eBay!) with 591 hours. Now I have 918 on it. I probably don't need it, but I sure love having it and there's lots of stuff I wouldn't have done without it. My only real concern is the mower height cam and finger are worn pretty badly; tough to get the mower to stay in Top position.
2015 Peterbilt 389 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 389...
2001 Dorsey 48ft Flatbed T/A Trailer (A56857)
2001 Dorsey 48ft...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
