HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20
   / HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #31
Ordered the gauge so I can routinely check the pressure. Would someone post a pic of where you are connecting the pressure gauge in the FEL system??
   / HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #32
I believe the point where gauge connects to test FEL is mentioned in post #1... For FEL it uses one of the 4 output ports for FEL....
Dale
   / HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #33
Yes but I would still appreciate a photo.....
   / HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #34
Just disconnect a hose leading to the loader, plug in the gauge on the tractor side, rev up the engine, activate the loader function, read gauge.
Easy.
   / HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #35
Here is our video showing the procedure on a JD tractor, but it’s the same for all colors.
   / HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #36
In the video all the hoses to the loader are disconnected. I was wondering if only a single hose was disconnected if fluid could go through that circuit and spray out the single disconnected hose. Could that happen??
   / HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #37
Most hoses with quick disconnects have a "ball" seal (or some type of seal) so when disconnected there is no "open hose" for oil to leak out of....
Dale
   / HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #38
If that were the case you'd get air in the lines and have to bleed the system every time you took the loader off. The hoses are just like the female quick connects for air compressors and close when disconnected.
   / HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #39
On a compressor hose the female coupler seals, but not the male part of the quick disconnect.
12 X 20 CAR PORT (A58214)
12 X 20 CAR PORT...
SCAN TO RECEIVE TEXT UPDATES (A52708)
SCAN TO RECEIVE...
Cushman Electric Cart (A55853)
Cushman Electric...
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
2017 International ProStar Truck, VIN # 3HSDJAPR4HN677698 (A57453)
2017 International...
2011 DOOSAN G40 GENERATOR (A55745)
2011 DOOSAN G40...
