How to fix crushed Gas can
   / How to fix crushed Gas can #1
twinjayhawks
NE of Tulsa, OK
Century 3045
Does anyone know an easy way to rehabilitate a crushed plastic gas can? I am not sure why this happens... and I don't really care. I have about 5 cans that look like this. I am looking to make them useful again.
   / How to fix crushed Gas can #4
Any way to blow a little compressed air into them?
   / How to fix crushed Gas can #5
"Smart" was not a part of your request for an "easy way to rehabilitate a crushed plastic gas can.":D
Drain and set out in the sun for a day and all the moisture will be gone.
   / How to fix crushed Gas can #6
The problem results from a warm can being sealed, then cooled. The cold air contracts and sucks the sides in....
No problem with the water, just let them dry before adding fresh diesel. (or whatever you keep in blue tanks)
Leave empty cans with the top a little loose so air can get in and out with temp changes...
   / How to fix crushed Gas can #7
I would go with the hot water idea, I think it would need a little hotter than tap water out of the water tap though.
david
   / How to fix crushed Gas can #8
Fill with hot water then apply a little air pressure to expand. This could be done by just blowing into the spout (dont forget to open the pour valve) if you dont have an air compressor. With extremely hot water in the tank, it wont take but a very little pressure to expand it. If using your compressor, go gently with the air or you could explode the tank as the plastic will be pretty soft.
   / How to fix crushed Gas can #9
Is that smart to have water in a gas tank?
The amount of residual water left in the gas tank after emptying is considerably less than what is already in the fuel. You would not even have to wait for the insides to be completely dry. It may be a good idea to know why it happens so you can eliminate the reason for any future purchases.
   / How to fix crushed Gas can #10
easiest 2 cures
1 put them in the back of my truck, every can back there swells up like a possum on the side of the road.
2 carefully remove the lid of your trash can, quicly insert all the unvented safety cans, carefully replace lid on trash can.
2020 DRAGON ESP...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
2013 Freightliner CASCADIA DAY CAB (A59575)
2013 Freightliner...
2020 ASV RT65 (A60462)
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
2013 Grove TMS 9000E 110 Ton Hydraulic Truck Crane (A60460)
2013 Grove TMS...
