how to keep stuff dry under new deck- need ideas
   / how to keep stuff dry under new deck- need ideas #1
Scotty Dive
Ct
Yanmar 2020D
So I have a new deck and its a good spot for my tractor until I build a shed. Is there an easy and good way to shed the water away. I know I can cover the tractor with a tarp, but with my exhaust sticking straight up its a pain. Here is a picture of under the deck with beam.
   / how to keep stuff dry under new deck- need ideas #2
My house walks into the basement and the main walkway to the door is under the deck above, so I needed a similar sloution.
What I came up with is placing the plastic corrugated roofing sold at the box stores to put overhead. I shimmed it so the water would run down (pitched) to the end where I have a gutter to a downspout and underground.
   / how to keep stuff dry under new deck- need ideas #3
I would look into getting an exhaust flapper from TSC or somewhere else if possible no matter what, if the exhaust is pipe straight up.
You could use tin sheets for a false roof under the flooring and above your tractor, but that may be cost prohibitive.
   / how to keep stuff dry under new deck- need ideas #4
Could cut a hole in the tarp for the exhaust then put a tin can on it to keep water out of the exhaust. Another possibility would be to attach the tarp to the bottom of the deck.
   / how to keep stuff dry under new deck- need ideas #5
Put a roof over the deck, then close off the sides with glass and do the same with the area below the deck.
Dry storage. A dry place to sit out of the rain!:thumbsup::thumbsup:
   / how to keep stuff dry under new deck- need ideas #7
There are several kits avalible on line or from big box stores for under deck drainage.
   / how to keep stuff dry under new deck- need ideas #8
The previous owner of my home used corrugated aluminum roof and pitched it to a gutter...
He said it took awhile to install and he also make a quick attach or sorts to one of the deck boards to get a garden hose in to flush if necessary.
   / how to keep stuff dry under new deck- need ideas #10
We have a walk-out basement with a deck overhead. We have a system similar to the TimberTech and it works really well. It channels the water out to the end where it falls into a gutter. We get a few drips of water where the deck meets the house but the patio stays dry. I park my motorcycle under there in the summer. I think it was around $900 installed. Also makes a nice finished look to the underside of the deck.
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A56438)
Bulk Lot of NEW...
2017 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A60460)
2017 Peterbilt 567...
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
1959 DODGE D510 DUALLY FLATBED TRUCK (A59823)
1959 DODGE D510...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2019 INTERNATIONAL...
