How well do shelter logic hold up in heavy snow areas?
   / How well do shelter logic hold up in heavy snow areas? #92
This is the one that I use....20 X 12 X 10.....it has a steeper pitch roof...snow does not accumulate but simply slides off....I also have the round top 24 X 12 X 10 however it does have a tendency to accumulate snow on top under certain conditions such as wet snow etc....
Buddy of mine has this one also, I like it, they weren't available when I purchased mine or I would have went with this one, I like the Inside height, he also made a front door for his to eliminate that pain in the neck zippered front.
   / How well do shelter logic hold up in heavy snow areas? #93
Skyhook: yes that zippered front is certainly a pain...best I could do to at least improve on it was to replace the crappy plastic inside "pulleys" with small 3/4" steel double pulleys....improves the lifting action a great deal and much less cursing involved....Twister
   / How well do shelter logic hold up in heavy snow areas? #94
I'm going to put sliding barn doors across the front of mine.
   / How well do shelter logic hold up in heavy snow areas? #95
Ditto that.......just haven't got around tu it yet.
   / How well do shelter logic hold up in heavy snow areas? #96
Next time I'm over at his place, I'll take a pic of the doors he made, pretty simple to make, two sheets of plywood and some 4x4's for the frame, the doors are in 2 foot sections.
   / How well do shelter logic hold up in heavy snow areas? #97
I'll say this about the ShelterLogic company, any concern that I've had about anchors, zippers, condensation etc., they took care of it right away.
The one "heavy 1 inch rain......followed by 1/2 inch sleet......then 4 inches of snow" did no damage to the unit. And it has sustained winds up to 50 mph so far without an issue. I installed it last summer.........a 12 x 20 x 8 SP series with the most heavy cover.
However, where I live in Kansas, is not considered a "heavy snow area" per the OP's thread title.
   / How well do shelter logic hold up in heavy snow areas? #98
Skyhook: pics of your buddy's doors would be great...might give us some ideas for our own...twister
   / How well do shelter logic hold up in heavy snow areas? #99
Sorry for the delay...here ya go...
   / How well do shelter logic hold up in heavy snow areas? #100
Sorry for the delay...here ya go... http://imgup.net
Doors look real good. Did you consider installing a lover vent in the doors to cut down on the moisture.
All I have is my frame up I'm waiting for better weather to install the cover, but I may start making some plywood doors now that I've seen your.
2017 JOHN DEERE 437E KNUCKLE BOOM LOADER (A52705)
2017 JOHN DEERE...
(APPROX 23) 2" X 2" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 23) 2" X...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A55302)
2012 RAM 5500...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
