How well do shelter logic hold up in heavy snow areas?
   / How well do shelter logic hold up in heavy snow areas? #81
I also hard sided the front, didn't like the zipper door and made wood doors for the front.
Any pics you can share on the hard sided front? Want to add to my snow/wind load rated shelterlogic (the big one).
   / How well do shelter logic hold up in heavy snow areas? #82
I'am setting up a 12x20 round top shelter logic and had planned to set cinder blocks in the ground under each footing and use the screw in ground anchors on the ends. After reading your post I'm having second thoughts.
What type concrete blocks did you use.
sand or stone around outside skirt i found works best. Mount the bottom to 2 x 6 then put inside and out. If any amount or shall I say large amount of wind gets under neath you will find it in the neighbors field! Not a fan of the screw in anchors, i didn't have any luck.
   / How well do shelter logic hold up in heavy snow areas? #83
I put a floor in my Jeep garage-in-a-box. It is 4x4's lengthwise where the wheel tracks are and 2x8's crossways with 1/2" to 3/4" gap in between for snow and slop to fall off. The 4x4s are pressure treated. This was after putting it up twice.
The SL for the tractor is sitting on the ground with Railway ties for anchors. At the four corners are 4x4's driven into the ground 6' and it is anchored to the corners. It is protected from the wind by the house on the south side and from the north wind by the bush.
   / How well do shelter logic hold up in heavy snow areas? #84
Sorry Msamt, I just read this, I haven't been getting notifications lately from this site, yes, I'll take a few pics today and post them for you.
   / How well do shelter logic hold up in heavy snow areas? #85
No worries, and many thanks!
   / How well do shelter logic hold up in heavy snow areas? #86
I am waiting patiently for pics, too.:)
   / How well do shelter logic hold up in heavy snow areas? #87
I bought a round top Shelter Logic 12' W x 12' H x 28' L building. I put it behind my existing shed, they're the same aprox. length, sheltered by the shed from the wind and by trees, to keep the sun off the cover. I threw down stone for the 'floor' surface area, and built connected 4 x 4" PT as a base for the feet to be lagged into. I drove rebar through the 4 x 4's to keep them from moving and secured everything with the cables and ratchet straps. I also used plastic coated aircraft cable at both ends at the very bottom of the outermost tubing sections to keep the 'mouth' from being able to open beyond specs.
I've had this SL in place here in VT with ridiculous amounts of snow, wind, ice, rain etc, and never once given a thought to clearing the snow or ice from the top or sides.
I use zipper lube from West Marine to lube the zippers to make them function. They are, IMHO the weakest part of the entire setup. This last winter the zippered door on one end did break the zippers. I bought a kit that allows for zipper replacement, IN PLACE, but have not installed them yet.
I would not buy anything but a round top unit in any northern clime that experiences large amounts of snow. I've had this unit up for at least 6 years, no problems other than noted.
Take time, do it once, level, square, plumb, and as protected from exposure to high winds and sun, if at all possible.
   / How well do shelter logic hold up in heavy snow areas? #88
Here they are...You can see the addition I added at the back of it. I have a wood stove in the addition, this is my second tarp in 5 years, I also added the second frame of the new one inside "doubling" it's strength. The frame is now 2 feet apart as opposed to 4 originally.
   / How well do shelter logic hold up in heavy snow areas? #89
This is the one that I use....20 X 12 X 10.....it has a steeper pitch roof...snow does not accumulate but simply slides off....I also have the round top 24 X 12 X 10 however it does have a tendency to accumulate snow on top under certain conditions such as wet snow etc....
   / How well do shelter logic hold up in heavy snow areas? #90
That is the one I use for my Kioti.
   / How well do shelter logic hold up in heavy snow areas? #92
Buddy of mine has this one also, I like it, they weren't available when I purchased mine or I would have went with this one, I like the Inside height, he also made a front door for his to eliminate that pain in the neck zippered front.
   / How well do shelter logic hold up in heavy snow areas? #93
Skyhook: yes that zippered front is certainly a pain...best I could do to at least improve on it was to replace the crappy plastic inside "pulleys" with small 3/4" steel double pulleys....improves the lifting action a great deal and much less cursing involved....Twister
   / How well do shelter logic hold up in heavy snow areas? #94
I'm going to put sliding barn doors across the front of mine.
   / How well do shelter logic hold up in heavy snow areas? #95
Ditto that.......just haven't got around tu it yet.
   / How well do shelter logic hold up in heavy snow areas? #96
Next time I'm over at his place, I'll take a pic of the doors he made, pretty simple to make, two sheets of plywood and some 4x4's for the frame, the doors are in 2 foot sections.
   / How well do shelter logic hold up in heavy snow areas? #97
I'll say this about the ShelterLogic company, any concern that I've had about anchors, zippers, condensation etc., they took care of it right away.
The one "heavy 1 inch rain......followed by 1/2 inch sleet......then 4 inches of snow" did no damage to the unit. And it has sustained winds up to 50 mph so far without an issue. I installed it last summer.........a 12 x 20 x 8 SP series with the most heavy cover.
However, where I live in Kansas, is not considered a "heavy snow area" per the OP's thread title.
   / How well do shelter logic hold up in heavy snow areas? #98
Skyhook: pics of your buddy's doors would be great...might give us some ideas for our own...twister
   / How well do shelter logic hold up in heavy snow areas? #99
Sorry for the delay...here ya go...
   / How well do shelter logic hold up in heavy snow areas? #100
Sorry for the delay...here ya go... http://imgup.net
Doors look real good. Did you consider installing a lover vent in the doors to cut down on the moisture.
All I have is my frame up I'm waiting for better weather to install the cover, but I may start making some plywood doors now that I've seen your.
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
2019 CATERPILLAR 239D3 SKID STEER (A60429)
2019 CATERPILLAR...
