Huskee log splitter B&S engine crankcase full of gas!
   / Huskee log splitter B&S engine crankcase full of gas!
Well got the new carb and fuel shutoff valve installed and everything runs great! Then I checked the hydraulic oil to make sure it was still at the correct level and found this:
I knew it was a mistake to store my log splitter outside and not under cover this last summer!
I *assume* that this is water in the hydraulic oil, either from condensation or, more likely, water leakage or ingestion. Thus far, I'm about 4 oil/diesel fuel changes in and it's now finally starting to come out not so milky. One or two more oil changes and I should be be ready to get back to firewood processing again.
Thanks,
   / Huskee log splitter B&S engine crankcase full of gas! #42
If your splitter is like mine the dip stick is also a breather (and it's not water tight). I always store my splitter with the ram retracted so the chrome part is inside the cylinder so it can't rust and either under a tarp or more often under a raised shed.
It's a standard 22 ton Huskee log splitter that everybody and his brother, there's probably millions of them out there.
Expensive lessons learned. :(
2024 JOHN DEERE 8R 280 LOT NUMBER 7 (A53084)
2024 JOHN DEERE 8R...
BUYER'S PREMIUM INFO (A53084)
BUYER'S PREMIUM...
2010 Chevrolet Equinox SUV (A51694)
2010 Chevrolet...
UNUSEDX-STAR 72" QUICK ATTACH GRAVEL LEVELER (A51247)
UNUSEDX-STAR 72"...
2008 GREAT DANE 53x102 DRY VAN (A53426)
2008 GREAT DANE...
UNUSED RAYTREE RMBC72-72" BLOCK CRUSHER (A51248)
UNUSED RAYTREE...
