hydraulic filter
/ hydraulic filter #1
alpha
Brimfield Ma
Jinma 354
has anyone added a hydraulic filter to a jinma? Thinking of adding one to keep the hydraulics clean and responsive.
/ hydraulic filter #3
That filter looks like a cartridge type fuel filter. Most hydraulic filters I have seen have been a canister type like an oil filter. The filters in the pictures looked like they were on the verge of collapse.
/ hydraulic filter
Thanks for all the information. I'm new to the Jinma tractor and could use all the info out there.
/ hydraulic filter #5
Well - I said it's GOT one. I didn't go as far as to say it's got a GOOD one. But it's more rigid than it appears in the photos. Biggest problem with it is the house of cards design. See attachment. If that bottom bolt backs out, the whole thing self destructs inside the reservior. Damned hard to clean without damaging/distorting the screen too.
//greg//
/ hydraulic filter #6
Is there any way you could install an after market canister type and just do away with the cartridge type? It looks like a time bomb just waiting to explode.
/ hydraulic filter #7
I have seen pictures, from people who added canister filters to the return line. They were mounted on the left side of the tractor, infront of the hard line return, by the steering control valve. If you do this, before removing the filter in the tank, check 3pt hyd return. I think it goes direct to tank vs return line.
/ hydraulic filter #8
Return line? But isn't the point to have the filter BEFORE the pump?
//greg//
/ hydraulic filter #9
No hydraulics expert, but believe there are filters designed for either suction side or return side. In a hyd system like Jinma's, ie not one shared with with transmission, the tank doesn't generate any metal particles. The particles come from wear of the pump and cylinders. The particles are trapped before entering the tank. I also believe that suction side filters must have tighter tolerances to not effect flow rate. A restriction has more impact on suction side than return.
PS: I said I saw pictures, didn't mean it was done by a hydraulics engineer /forums/images/graemlins/blush.gif
/ hydraulic filter
the filter on a 354 is on the suction side ie the drivers side of the tractor and there is metal in the tank I just drained mine and flushed with kerosene.
/ hydraulic filter #11
I believe it is a similiar screen filter as the 200 series, just side mounted vs top. If the tank was clean from mfg (big if), the particles are deposited when the oil returns to the tank. The heavy ones will deposit on the bottom and the others will be drawn into the screen. I have changed mine once (284) and it wasn't a big deal. It didn't appear to have much on the screen, but since I had spares, replaced it, and will clean at a latter date.
PS: The side mounting on the 304/354 makes it a bit more messy.
/ hydraulic filter #12
I can barely spell hydraulix either John. But common sense says the pump is PULLING fluid through a filter on the supply side, which means it would necessarily have to PUSH it through a filter on the return side. Except for the filters/strainers in my water supply and air compressor lines, I can't think of any other application off the top of my head that is a PUSH.
Oops - the Jinma fuel filter is a push, isn't it........?
//greg//
/ hydraulic filter #13
Look at Northern Hyd and you will see suction side strainers and return line filters.
See attached for pic I was talking about:
Most oil filters on engines are push, correct?
/ hydraulic filter #14
That Northern link cleared things up John. But it appears that a return filter should only be in ADDITION to the supply filter, rather than be considered as a convenient way to replace the existing filter/strainer.
I take that back about the fuel filter. The injector pump pulls fuel through the filter, then pushes cleaned fuel toward the injectors. And I think you're right about engine oil filters though, otherwise bypass valves wouldn't be rated in PSI.
//greg//
/ hydraulic filter #15
Yes, you need a suction side <font color="blue">strainer </font>. The suction side <font color="blue">filter </font> on Northern's site, includes a 149 micron screen strainer. Again, not an expert, but think the norm is filter on return line.
If you add a return line filter, I recommend leaving the factory strainer/filter in place.
/ hydraulic filter #16
Just a little note.
All pumps in general require that the piping on the suction side of the pump be as straight as possible before entering the pump. In addition a filter should be installed on the pipe suction side of the pump preventing any foreign material entering and destroying the pump. This is a general rule of thumb. Although the filter should not be located too close to the pump. The pump needs continuous laminate flow of fluid (not turbulent). Turbulent flow or restricted flow is how most pumps fail. So keep the filter clean at all times.
/ hydraulic filter #17
Wouldn't hurt to add one in line to tank. I'm thinking of doing it because of the flimsy filter under the seat. More is better inmy book /forums/images/graemlins/grin.gif
/ hydraulic filter #18
that filter in the lnik is on the LEFT side, is that taking the return power steering fluid only then? as the photo shows what looks like garden hose not hyd hose for attaching the filter!?
I know John probably didn't take the photo but do you know any more?
Just wondering
Mark M /forums/images/graemlins/smile.gif
/ hydraulic filter #19
Spiker what photo are you looking at? The hydraulic line on my unit is steel.
/ hydraulic filter
I'm still interested in the idea of a reurn side filter but how can ya cut the steel return line and attach any fittings.
2018 ALLMAND MAXI-POWER 45 GENERATOR (A58214)
2018 ALLMAND...
BOBCAT S250 TURBO SKID STEER (A62129)
BOBCAT S250 TURBO...
2018 GENIE GTH-1256 (A60736)
2018 GENIE...
2025 Unused SDLGC80 60v Electric Golf Cart (A60352)
2025 Unused...
2015 Jeep Wrangler Rubicon Vehicle (MPV), VIN # 1C4BJWFG8FL728783 (A61165)
2015 Jeep Wrangler...
2016 PETERBILT 389 FLATTOP (A60736)
2016 PETERBILT 389...
