Hydraulic power fading with normal use.
   / Hydraulic power fading with normal use. #1
nox273
Australia
Building
Hello all.
I have an older model Dingo type skid steer mini loader that I am having some issues with around losing power with prolonged use.
When I first start and use the loader the bucket lifts well and crowds equally as well, it drives forward and backwards, skids to the left and right pretty good.
The problem starts when I have been using the loader for any longer than 1/2 an hour the hydraulic performance starts to drop off to the point where the loader finds it difficult to skid steer at all.
Both lift cylinders and crowd cylinder appear to function well. The loader will still drive forwards and backwards although slightly slow than when cold but doesn't seem to have the same grunt as when it was cold.
This comes quite annoying as the oil becomes quite hot (50C - 60C) and takes sometime to cool down. Here are some details of my machine.
Motor - Honda GX390 - 13hp - 3500rpm (44 hours old) - (yes a little under powered)
Pump Casappra - 9cc (Group Din 2) - (44 hours old)
Crowd cylinder is a single 2" ram
Lift cylinders are 2 x 2' rams
4 x Vickers branded CR18 wheel motors - 285cc - 180rpm (new seal kits in all motors 15 hours)
Oil capacity approx 43 litres (new oil only 30 hours old) - Fuchs Renolin B 68
Reconditioned valve block (approx 60 hours)
System pressure ? - Waiting on pressure gauge to arrive.
Any body have some ideas on where I should start looking. Any help would be muck appreciated.
   / Hydraulic power fading with normal use. #2
Has it just started doing this, or has it been doing it all along?
Your pressure gauge is the right starting point to figure it out. Start with the main system pressure and see if it drops off as the oil heats up. If it does, then it's probably the system relief valve or the main pump. If the main pressure remains high, then check the pressure in the drive motor circuits. If those are dropping off then it's either the control valve or the motors themselves. It would probably be worth checking both motor circuits to see if they behave the same or differently.
   / Hydraulic power fading with normal use. #3
hayden offers some good suggestions ^^^^^
How many hours on the Dingo? Might be excessive wear on the wheel motor(s). It would be helpful to know if it heats up while stationary, not using the wheel motors and raising and lowering a full loader bucket.
It has done this all the time I have owned it. The previous owner put in the new pump and motor and rebuilt the valve block.
I changed the oil even though the old oil looked nice and clean. I also had the new seal kits put in all motors by a hydraulic shop and the mechanic said the motor while a number of years old were in very good condition and showed very little signs of wear.
Not sure how old the machine is, late 90's I reckon. I would have to check if it heats up as quick when stationary.
I was thinking does the pump supply enough flow once warm to drive all 4 motors.
   / Hydraulic power fading with normal use. #6
I couldn't find the motors online, but 50-60c (122-140f) seems on the cold side for vg68. I would expect vg32 at those temps. The thicker oil could be masking some wear or leakage until you get it to that temp.
As it gets hotter and you lose performance, does the engine seem to work harder or easier?
ISZ
ISZ
The engine seems to bog a little less when hot than it does when cold. Not a huge difference but noticeable.
I have also noticed when all is hot and you are trying to skid steer not all wheels rotate at the same speed and appear notchy in there movement a bit like clockwork as if there is not enough fluid to drive all 4 motors at the same time at the same speed. When cold they are much smoother.
Hopefully my pressure gauge will arrive in a couple of days and I will be able to narrow it down with some gracious help of the forum.
ISZ
What temperature would be considered normal operating temperature for 68 weight oil.
ISZ
Link to motor below. Model is CR18
Products | TOKYO KEIKI U.S.A., INC.
   / Hydraulic power fading with normal use. #10
Pump is more than likely worn. Need to do a test with a flow/pressure meter. The hotter the oil gets the more a pump will slip and create more heat. Vicious circle. 95% of the time with these symptom the pump is the problem. Not a fan of Cassapa pumps. CJ
DECORATIVE METAL GATE (A58214)
DECORATIVE METAL...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
402 (A52706)
402 (A52706)
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Kubota B2301 (A53317)
2019 PJ  40FT GOOSENECK TRAILER (A58214)
2019 PJ 40FT...
