Hydraulic SSQA Plow Troubles
   / Hydraulic SSQA Plow Troubles
ok, that is what I will do- I will mount one Da cyl on the rh side, where my plow is normally straight or angled right so the load is on a closed cylinder when angled. Thanks a lot for you help JJ, I appreciate it- Ron in Maine~
   / Hydraulic SSQA Plow Troubles #12
Since you chose to install a DA cyl, I would install a double relief valve across the cyl for shock protection.
   / Hydraulic SSQA Plow Troubles #13
As I mentioned on the OTT forum, I believe your trouble is the regen function of your valve. Try pushing the joystick further to the right to get out of the regen portion of the valve. And as I mentioned a search of the word "regen" will turn up tons of reading.
That is a great writeup KennyD. I appreciate you sharing that with me- It makes a lot more sense now. I will try this this weekend and let you know. You know hydraulics seem like they would be a relatively simple thing, but there is more to it then in and out I guess. I know when I put my grapple on, I installed the diverter valve everything went well. I fired up my machine and tried to operate the grapple and it did not work properly at all- kind of did the same thing the plow does- my hoses were backwards on the grapple. You would not think it would make a difference, just run backwards....
   / Hydraulic SSQA Plow Troubles #15
Just take both single cylinders off, and replace with them with one double acting cylinder. U will just have a cylinder on one side, not both. What u do for running lines along the loader arms. Just regular hydro lines ??
Yes, that is my plan. I will buy a new DA cylinder the same stroke and do that- yes just regular 3/8 line with brackets that hold it to the inside of the loader arms all the way to the diverter valve.
   / Hydraulic SSQA Plow Troubles #17
Ron, 1/4" hose is really all you need since the small cylinder is really a low-flow device, it may help slow the cylinder down a bit as well to keep the plow from slamming from side-to-side. I hope the DA cylinder works for you, but if it's truly a regen problem it may exhibit the same lock-up tendency the two SA cylinders did.
Yes, I will run 1/4- But why wouldn't one DA cylinder work- I was thinking about it, if I took the DA cylinder off of my grapple that works just fine lines and all, and pinned it to my plow it would work- it would have to- I have not changed anything except what it is pinned to.... Someday I will understand this hyd stuff better...
   / Hydraulic SSQA Plow Troubles #19
A DA cyl will work.
   / Hydraulic SSQA Plow Troubles #20
It may not work because there is no mechanical advantage to help extend the cylinder like there is with the weight of the bucket on a FEL. I wrote that in some of the material I referenced on the OTT forum. If you search the term regen, particularly in the Kubota and JD forums, you'll find lots of threads about only being able to move a snowblower chute one way for this same reason.
Here is a great explanation of what regen is: http://www.tractorbynet.com/forums/kubota-buying-pricing/9403-3-position-valve-vs-4-a.html
Some threads to read:
http://www.tractorbynet.com/forums/...aulic-shoot-rotator-goes.html?highlight=Regen
http://www.tractorbynet.com/forums/...578-b2630-hydraulic-help.html?highlight=Regen
One related to a motor: http://www.tractorbynet.com/forums/...nnect-problem-snowblower.html?highlight=Regen
2005 FORD F-150 XL (A58214)
2005 FORD F-150 XL...
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
2001 INTERNATIONAL 4900 (A58214)
2001 INTERNATIONAL...
2017 JOHN DEERE 437E KNUCKLE BOOM LOADER (A52705)
2017 JOHN DEERE...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
