Hydro Cooler Failure TC-40D
   / Hydro Cooler Failure TC-40D #31
I think I would take it to a good metal fab shop, that has experience welding aluminum, and let them have a go at it. The fact that there was fluid in it, and probably in the crack, will give them a little difficulty, but if they clean out the area and crack good, I think they'll have no problems.
I noted on my cooler that the weld area seems to be much more substantial than what is shown on others that cracked. In fact, I kind of like the more substantial weld than the washer fix, but time will tell.
   / Hydro Cooler Failure TC-40D #32
Update on bad cooler...
I couldn't find anyone local who would even touch it. The first person I showed it to knew exactly what it was, 'cause he had another one EXACTLY like it on his shelf. He had tried to repair it, but it didn't go so well.
As far as talking to my dealer, no luck. Since NH hadn't put out anything saying they would replace them, he wouldn't.
So $230 (tax, shipping, clamps.. yeah, my dealer doesn't "just throw" anything in!) later, I am back in business. Still frustrating nonetheless.
   / Hydro Cooler Failure TC-40D #33
As you have bought a new one, how about sending me the old one and if I can repair it, you will have a spare?
   / Hydro Cooler Failure TC-40D #34
That is a great idea! Then, if all goes well, you can do it for the others here (charge for it of course). A new business!
Why do you think you can do it? Prior experience?
Bob
   / Hydro Cooler Failure TC-40D #35
I do the motorcycle radiators and Oil coolers on occasion, and I believe (although I have never done a tractor one) that they are the same.
I try to do some projects just to keep in practice, TIG welding is a perishable skill.
And as I have never done one, it would be nice to say, yep, I fixed one of those....
   / Hydro Cooler Failure TC-40D #36
very cool. I hope you get to try and take some photos and post them and your experience.
Bob
I'm a pessimist when it comes to making a repair on a hydro cooler. Lets hypothetically say that someone is able to repair a leaking cooler. And after it's installed a small piece of the welding material comes out of the cooler and does some damage to heaven knows what before the filter can catch it. Is the risk worth the cost of a new hydro cooler? Not in my opinion.
   / Hydro Cooler Failure TC-40D #38
Very good points.
Bob
   / Hydro Cooler Failure TC-40D #39
Do you have much weld 'inside' the cooler?
What about flushing it?
Soundguy
   / Hydro Cooler Failure TC-40D #40
So im new to the sceen (should have my TC33 in a month or so)
but the oil cooler up front looks like a generic stacked plate cooler.
a quick check of jegs or summit will give you about 5 diffrent versions that i bet are a direct replacement for about half the cost.
linky linky Shortened linky linky
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59575)
2020 INTERNATIONAL...
UNKNOWN  500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
20FT X 12FT LIVESTOCK METAL SHED (A58214)
20FT X 12FT...
48" Pallet Forks (A59814)
48" Pallet Forks...
Chemical Containers Tank (A57148)
Chemical...
