I need some help from a plumber
   / I need some help from a plumber #21
. The second somebody catches you pumping sewage across your yard and it's leaking out of the pipe is the day you wish you had never been born. It will smell bad and all it takes is one complaint to get somebody out there. Is it really worth saving a buck to try to go this route?
Good luck,
Eddie
The EPA and the health dept would have a field day with that.
I guess I still don't understand why it would be leaking out of the pipe or hose :confused: If it leaks on either end where I hook up to it, it would only be leaking back into the tank or into my outside sewer line for the business.
Oh, and the house and the biz..... just me and the occassional customer who needs the restroom. I'm not worried about taxing that system at all. The extra waste would do it some good.
I'm not doubting that sewage freezes as you seem to have experience with it, Egon and Highbeam, but I gotta ask after speaking with my father and someone else today who don't think it freezes; Why aren't leach fields below the frostline then?
I know for a fact that my leach field for the business isn't more than 2 ft deep. And taking that into account, the line that feeds it would only be a couple feet deep, too.
And my father mentioned putting in a septic system at a camp he used to have and he said that wasn't below the frostline. The guy he was with agreed. Granted their both older and may have forgotten, but I know I didn't forget.
I'll keep you all updated and appreciate the extra input to kick around.
   / I need some help from a plumber #23
Exothermic aerobic action in the leach fields produces heat. That with the ground, vegetation and snow cover prevent freezing. The septic tank itself also has exothermic anaerobic action so the effluent to field will not be cold.:D
If in doubt clear off the vegetation and snow regularly and drive over your field system during the cold winter months. :D
Note: There are newer systems than what I describe with which I am not familiar.
The danger of freezing is also dependent on the mean ambient temperature over a period of time.:D
   / I need some help from a plumber #24
I guess I don't understand why you would want to go to the trouble of pumping down a septic tank every few weeks instead of just putting in a new drainfield, it's not that hard and it does'nt cost that much for the material to replace it, at least around here where I am at. One days time and labor verses being tied down however many weekends pumping out a septic tank,that maybe one day I might get city sewer, but I did'nt see many other opinions leaning towards this so I might be the only one thinking this way. Good luck whatever you decide.
   / I need some help from a plumber #25
Freds, You're looking for answers without defining the question so you're getting a mix of pertinent & non-pertinent but all valid advice. The guy that just pumped your tank should have told you that a tank should be filled with water immediately after pumping to keep solids in the tank. You paid a lot of money for a very temporary solution, which you both may have known.
Leach fields get waterlogged from running toilets or just overuse as well as get saturated/plugged with solids/grease/soap. Tank inlets/outlets get plugged with lots of things & scale/grease/soap will build up in pipe until there's no hole to flow thru. After hearing much "I told you it needed to be pumped more often" from my SWMBO I once climbed down into my just pumped & rinsed septic tank only to retrieve a cleaning cloth from the tank inlet elbow which she immediately recognized and for a moment was unnaturally silent. ( Yes - I climbed into my own septic tank! How much would any of you charge to climb into someone else's ?? I ain't got that kind of money. )
First of all you need to determine exactly what has failed. Dig up the outlet & pipe away from the tank. You should find a small tank called a distribution box. This is where the lateral perforated pipes that disburse the effluent start. Take off the cover & see if there's water flowing into it. If not the trouble is back toward or at the tank. Clean this pipe as necessary. If the D box full of water the receiving soil is waterlogged and/or plugged with solids. Households with smaller septic tanks that flow a lot of hot water, showers, dishwashers, etc, have more suspended solids leaving the tank.
If the leaching soil is plugged it must be removed & replaced or the leach field relocated. This may be as simple as exposing the pipe & removing 12" under & each side & replacing with good clean sand which can be done with a shovel.
Or as a semi-permanent solution you can put in a holding tank at the septic tank outlet with a float activated effluent pump (usually 2 pumps with different start levels are installed to allow the spare to be activated should one fail at an inopportune time) pumping to your other system. Pump thru 1 1/2" or 2" pvc without a check-valve to allow drain-back which precludes freezing. This is done all the time in raised bed leach fields. The holding tank needs to be sized to accept the run-back without restarting a pump, i.e. 20 gallons out - 2 gallons back - 18 gallons until next pump start. Also keep in mind how big a batch your other system can receive.
My advice is do a little digging before you spend any more money. On the bright side, maybe you could call MikeRowe & tell him you've got a "Dirty Job" that needs help. Take pics & keep us posted. MikeD74T
   / I need some help from a plumber #26
By the time you mess around jerry rigging something that may or may not work, think how much progress you could make on actually fixing the problem. It sounds like you've already had two backups, and that would be quite enough motivation to get this fixed. I remember when my Dad's system failed, and he ended up digging an entirely new system in a different area. That fixed the problem, and he hasn't had another problem in the last 15-20 years from it.
   / I need some help from a plumber #27
I agree with what Mike D said about checking dist. box,etc. The way you described your problem, both times your toilet was running,the system might be ok,but they can't handle constant water without having rest periods inbetween uses. Probably be a good idea to fix toilet or turn it off betweeen uses. I'm in septic business in NH. You ought to see what sprinkler systems do to flooding leachfields when homeowners mess with their zones and increase the time of sprinklers to get their grass to grow. there are upgrades you could do like filters,venting of field to get it to last longer. Your pumper should be able to give you advice if he has been doing it for awhile. plowking
   / I need some help from a plumber #28
There are a lot of people who done that. They didn't climb out on their own though.:D
   / I need some help from a plumber #29
Yea boy Egon's sure right about that. The wife's cousin sent me a linkything to another board where some poor University Professor in Ohio fell into his tank and they had the whole dang Fire Department and Rescue Squad there to pull him out. They even had to hose him off and pack him into a giant plastic bag before they could put him in the Ambulance to take him to the local hospital.
I seem to recall everything turned out for the better though cause the Professor fellow joined the Fire Department and found them a lot of grant money to buy new equipment with. After his In Tank Experience that fellow became a community leader, not just another transplanted city dweller. Seemed like he was a nice enough fellow.
   / I need some help from a plumber #30
Sounds like another case of 'this is why we have inspectors and the health department'.
It'll be cheaper and mostly safer in the long run to get it fixed properly.
John Deere 7410 (A53317)
John Deere 7410...
2012 Ram 2500 4x4 Crew Cab Pickup Truck (A59230)
2012 Ram 2500 4x4...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2005 Peterbilt 357 T/A A-Frame Gin Pole Truck (A60460)
2005 Peterbilt 357...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A59905)
2020 KENWORTH T680...
2018 Chevy Traverse 3rd Row Seating (A56438)
2018 Chevy...
