Ideas to make truck tow better
   / Ideas to make truck tow better
Your truck is 24 years old. That 1992 350 with 5 spd and 4.56 gears should have no problem towing 10K. Apparently its tired. I tow that much with a 5.3L (smaller than your 5.7L), 6 spd auto, and 3.42 gears. I also towed a camper that weighed that much years ago with a 79 Chevy 4x4, 350, 4 spd. manual and 3.73 gears.
If your truck body is in good shape I'd suggest buying a rebuilt truck 350 engine at your local auto parts store and drop it in with a new dual exhaust system. A lot cheaper than buying another truck.
george, I like this idea. Maybe even replace it with a 454. Before I get too far into this, I need to do a little more homework. Hate to put all that money in if I am way over weight to begin with. I will check some prices and see how much monkey business this could be. Thanks.
This is a 4x4 but you should be able to get half this much moving on level ground. An incline makes a big difference of course.
https://www.youtube.com/watch?v=YnZ5qjGGFh4
This was great. Thanks for posting that. I wish we could travel back in time to that era again. I*miss the way things were back when this commercial aired. Made me smile!
   / Ideas to make truck tow better #33
Mine was an '89 Ford F250 with a 351/4spd. It started and idle fine. But when accelerating or under any kind of load, it was a dog. It had been fine driving up the valley, but started getting doggy when I came out of Redding Ca up in to the mountains around Weaverville Ca. I pulled in to Weaverville in 1st gear... Had to tow it the last two miles to our friends house.
I was on a trip 4 hours from home in the mountains when it happened. It was a holiday; everything was closed, and I had limited tools with me. Dinked around looking at fuel, spark but that looked fine. Finally broke the bolts holding the Cat , tied it up to the frame, and drove home open exhaust...
I will ask and try to find out about a plugged cat convter. Still seems like this would cause it to struggle while moving as well as starting out.
   / Ideas to make truck tow better #34
If your tow load is truly around 10K I think you're maxxed out for towing capacity. The truck will tow the load but stopping may be an issue. Replacing the engine would definitely help but if towing that weight is done on a regular basis get a larger truck with greater towing capacity for safety. Today's newer 1/2T trucks are now in the 10-11K tow rating when ordered correctly.
   / Ideas to make truck tow better #35
This thread is really jumping around.
Problem Statement - Truck has low power at takeoff.
1st question - Has it always been this way, or is this a new problem?
The issue has to be related to only a few things. A gas engine needs air, fuel, spark, compression, and exhaust.
- Air - Is it getting enough air? Is air cleaner clean/new? No restrictions in the air path? Fresh air intake?
- fuel - Is it getting enough fuel? Too much fuel? Is the fuel pump pumping? Does it have a fresh fuel filter and new clean fuel? What do the spark plugs look like? Dark, light, ashen?
- Spark - What do the plugs look like? I have had varied performance with different plugs... What about the wires, rotor, cap? Has the timing been checked? Are the wires held in the loom properly? Had a Ford with a 400 that had to have the plug wires held in the holder along the valve cover properly, or else they would short to each other...
- Compression - engines are just a big compressor. What does the compression look like? After adding a bit of oil to cylinders(rings)? What does leak-down look like?
- Exhaust - What does the exhaust look like? My experience with a clogged Cat is no power above idle. It would be a dog at speed but should start off ok.
It's gotta be one of those four. Air, fuel, and spark are pretty easy to check. Compression is not too hard with right gauges.
   / Ideas to make truck tow better #37
But based on what? So far we know it is a dog starting out with a load. Could be the timing is off or something else simple?
He did say in his first post he doesn't have a problem once moving. It very well could be a timing problem. Possibly needs a new timing chain and gears if it has the nylon gear and a sloppy chain. He also has an exhaust leak which could be as simple as a gasket replacement. Could be a carb (or throttle body) problem. He has not done a compression test. I agree with it not being a clogged cat since he says high speed is OK. With his engine, granny gear low and 4.56 gears he should not have a problem on taking off. Timing gear and chain would be my guess if compression is good. He also said it uses oil and leaks some. At this point I'm just saying he needs some motor work or a replacement.
   / Ideas to make truck tow better #38
The 350 chevy had many different HP ratings depending on the year . I had a 69 chevy c 20 with a 350 / 350 hp . I had a 76 corvette with a 350 / 180 hp . Check the numbers on the block to make sure what you have
   / Ideas to make truck tow better #39
I still have my '73 K20 Cheyenne I bought new. We've grown old together. I'm sure it will outlast me.
   / Ideas to make truck tow better #40
I agree. He even said it sometimes stumbles with no load. Something is not right with the engine and all this talk about replacing differentials, smaller tires, new motors, etc is crazy at this point. That truck should move right off in granny low with that load.
It could be something as simple as low fuel pressure, egr problems, exhaust back pressure, (or even too little back pressure, as that can effect egr operation ), wrong egr valve installed, tps malfunction, timing problems, etc. First things first before replacing motors and gearing.
8ft Disc Mower (A57454)
8ft Disc Mower...
2013 Chevrolet Van (A55973)
2013 Chevrolet Van...
Case BPM13 Mixing System (A57453)
Case BPM13 Mixing...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
New/Unused 20ft Bi-Parting Iron Gate (Elk Design) (A57454)
New/Unused 20ft...
Skillsaw (A57454)
Skillsaw (A57454)
