Will do that J.J. ..
Moss was thinking the same thing about the screeching.. Sounded like it was coming from the steering column was thinking no way that's the steering rams. For the heck of it , I greased the rams good and after driving it around I lubed them again. The sound is now gone along with the faint knocking noise. I still can't figure out where that was coming from. Everything is much smoother now.
Now that the PT has had a good initial cleaning. I feel much better about using it . I'm thinking I've got a good solid tractor here, perfect for around my property. Even though the front lift arms are not bad, there is some wobble and play when driving around on pavement with the bar tires.
So I'm going to eventually replace the them and repaint everything else. I do wonder if anyone feels a slight vibration when mashing down the treadle going up a steep hill. I can feel it just little bit under my seat. Going to take cqaigy's advice and check all of the engine ,pump and wheel motor bolts and make sure they are tight.
Thanks to everyone for all of the input..
