iPad vs ?
   / iPad vs ? #81
I've mentioned NOT liking the non removable storage on Ipad. Besides that storage being expensive here is another reason. On my S4 I mentioned I had a 48gb card filled with photos. I misspoke, it's a 64gb card with 48gb of data. When I first got the card, I put in the phone, hooked the phone to the usb and proceeded to move my photo folder. The little window came up estimating the time left, and I forget the exact time, but it wasn't hours, but days. Needless to say I stopped that. Put the micro SD card in the SD adapter, put in laptop and loaded the card that way. Still took a fair amount of time, forget exactly but < hour. The point is.....with non removable storage on an ipad how do I get my data/photos over from my laptop? To me removable storage has a hug plus here.
Never seen anything close to that long to move photos from my phone to the computer. I moved I think it was more than 2,000 photos a few weeks back took maybe 20 minutes if I remember correctly. I'll check later tonight I have over 1,200 on my phone now. I'll move them to laptop via usb and let you know.
   / iPad vs ? #82
That would be good if the case. At the time I thought that is completely unreasonable....but why didn't have a clue. Either the phone...android...microsoft....dunno. But at the time it really stuck in my mind that move data at bus speeds in the the laptop is very different than via usb.
Just checked the number of photos/file in that folder 19,800+.
   / iPad vs ? #83
With nonremovable storage on the iPad you would move it by hooking your iPad up to the computer with the cable and moving it through iTunes. You might also be able to do it by not having iTunes and telling windows to open the folders on the iPad when it pops up and asks you what to do with the mass storage device you just attached.
I'm pretty sure it wouldn't take the days you saw as your S4 claimed, that depends on how much faster the onboard storage in an ipad is than the S4 using the SD card (using an SD card on ANY device, phone or PC, is much slower than using onboard storage, which I suspect is one reason Apple devices don't use it). I suspect the iPad wouldn't take days, or even hours because I've done iTunes restores on my devices with tons of music and pictures in much less time.
btw I also suspect the S4 wouldn't have taken days either if you had let it run for a while. I've often seen these operations start off estimated to take a ridiculous amount of time that quickly decreases to a reasonable level as the operation goes on. I don't know what the algorithm is for estimating remaining time but on Windows it starts out notoriously conservative.
   / iPad vs ? #84
You are not moving data off the microSD card at 'bus speeds'. The limiting factor is the speed of the microSD card, which is no where close to bus speed.
   / iPad vs ? #85
Get the card reader that plugs into the lightning port on the iPad. Put your card in the reader and import the files (of course you'll need to know what app or library you're importing them to, since there is no "file system" in iOS as far as the user knows). I have no idea how fast it is, but it would be faster than a USB sync transfer you were trying before.
Lightning to SD Card Camera Reader - Apple Store (U.S.)
   / iPad vs ? #86
Your correct bus speed isn't involved. But it wasn't the card either since with the micro card in the SD adapter plugged direct to the laptop it transferred at ok speed. So it was the phone or cable. I did let it run for awhile and it was obvious it wasn't the method to use. But you guys are correct a Samsung phone is not even close to an ipad on speed.
Is there a file manager under iOS so you can see the file structure, as with pc?
   / iPad vs ? #87
BTW what is the preferred photo editor on an ipad? Although i haven't used much, I've been looking at PicArts. Up to this point it's been the laptop and photoshop.
   / iPad vs ? #88
There are a bunch, but you could just use the Adobe Photoshop for iPad if you like that software.
   / iPad vs ? #89
Well I just moved 4.9 Gig of photos and videos from my iPhone to iPhoto. I was way off. It took 3 minutes to transfer using the provided lighting to USB cable that comes with the iPhone. Hope this helps.
   / iPad vs ? #90
I'd copy the photos off a tablet and onto a laptop/desktop to edit them. No way I'd try and edit almost 20,000 photos on an iPad.
FileBrowser for an iOS file browser.
12in Mini Excavator Tooth Bucket (A52377)
12in Mini...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
2012 Ford Escape Limited SUV (A53424)
2012 Ford Escape...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2023 Club Car Carryall 700 Utility Cart (A51691)
2023 Club Car...
