is a b7800 to big
   / is a b7800 to big #1
wantabota
eastern virginia
Bx2230
my property has 3.69 acres that is very flat with little obsticles and I would like to go with the b7800 but I was wondering if that would be a problem considering that we have a septic tank would the wieght of the tractor be to much. I am also plnning on building a barn to accomidate a horse so the tractor would be of very much help.
   / is a b7800 to big #2
For that amount of land I'd find it tough to go that big as unless you plan on getting a 72" deck you couldn't gain much. But for the difference in the price to the BX 23 to the 7800 with a mower and loader you would have all the options.
   / is a b7800 to big #3
wantabota
I have a B 2910 (same tractor as 7800 but more features) that I use on just over 4 acres. It was originally purchased to get the lawn done in a short time. It takes less than an hour to cut 2 acres with a lot of obstacles.
After owing it since 2000 I have found that it has many other advantages because of it's size compared to my neighbors BX. The biggest item is the load capacity of the FEL. 900 lbs. lift versus BX's 500 lbs.
Do a search on the B2710 and B2910 tractors. You will find a lot of information on there ability to do the jobs you want to accomplish.
   / is a b7800 to big #4
"...wondering if that would be a problem considering that we have a septic tank would the wieght of the tractor be to much. "
As far as the weight when driving onver a septic tank, you might want to check out this thread . It's pretty long and there's a lot of opinions and responses.
That thread should help you decide...
So, other then the price differential between the 7800 and the smaller Kubotas, probably no reason to not go for the bigger machine. Personally, I think the B7500 would be a better match for your property.
Either way, if you buy a tractor with a FEL, suggest you leave the FEL off when you're mowing. Less weight means less risk when you're driving across the septic tank and drain field.
   / is a b7800 to big #5
Maybe... /forums/images/graemlins/smile.gif
Well if it is lawn duty - the BX should be your pick.
Loader duty - yes the B7800 has the edge, put do you plan on
a thousand pounds of manure moving?
Weight? Factor the BX for you needs, riding around in tight places? BX, Ground clearance? B7800. But do you need it?
Horsepower - B7800, but do you need 'em?
I'd look at the BX first and go kick the tires and drive it around.
-Mike Z. /forums/images/graemlins/smile.gif
   / is a b7800 to big #6
Heyb there,
I just went through this. One thing you may want to consider is the size of the operator station. If your mowing 3 acres you want to be comfortable. The B7800 is a much lager38inX38 in operator platform than the BX or B7500.
If you are slim and trim the BX may be perfect for you but ride one around and get a feel for it's size. If your a wide body (like Me) try the B7800 on for size.
There is always the JD 2210 which is bigger than the Bx's and a bit more tractor, yet smaller than the B's (and quite alot less tractor too).
On the septic issue remember tire size, the B7800 is only 200 pounds heavier than the BX23 sans loader and that can be eaten up with a wide turf tire, or made worse buy the narrow R-4's.
Of course which ever Kubota you get you'll be buying the best small tractor in the business. Good luck
AJP
   / is a b7800 to big #7
I have 2.5 acres and a B7500. If I were buying today, I would probably step up to the B7800. It wasn't offered at the time I bought. The only reason I would step up is for the additional lift capabilities. Actually I was looking very closely at the BX22 when I bought. I am really glad I bought a little bigger than I thought I needed. One of the tasks I do is move pallets of firewood with my tractor. A BX would not be able to do that. My B7500 can just barely handle it and a B7800 could do it easily.
What it comes down to is really analyzing what you will be using your tractor for, regardless of the size of your property. If you are just going to be mowing, a BX will probably be great for you. If you are going to be doing any lifting I would recommend that you look at the specs of each tractor and then buy one size bigger than you need, if your budget allows.
Boy it's fun spending other peoples money...... /forums/images/graemlins/smile.gif
Greg
   / is a b7800 to big #8
I considered both the B7500 and B7800. I have 3 acres and thought the 7800 was too big for the mowing and tight work around the house. I wanted more capacity than the 7500 but preferred it's size. I bought a B2410 and got the size I preferred (and still do) and got additional lifting and breakout force of the 2410 (LA 352) loader as well as the additional 3 point lift capacity. It does not have the all the capability of the B7800, however. In my opinion, it was the right choice for me. I have loaded tires and a backhoe and drive over my concrete septic tank which is about 18 inches below grade with no problems. Good luck with your decision.
   / is a b7800 to big #9
I have 3.7 acres and a b2910 and I think it is a good fit. I actually wish I had a L3130 or L3430 sometimes! /forums/images/graemlins/blush.gif But that is only because I also have a BX2200...
In the beginning I thought the B2910 [same size as B7800] was BIG. But now I think it is just fine for most of my needs.
Had I bought a MMM I probably would not have ended up buying the BX2200. I had went with a 60" RFM and it did not work well for me because of things I had to cut around.
If I had to only have one tractor for my 3.7 acres it would be the B2910.
In fact...when I think about "my tractor" for some reason I forget about the BX and an image of the larger tractor is the only one that pops into my mind...
The B series tractors are actually pretty light...by the way... /forums/images/graemlins/smile.gif
I would go with a 72" mower on the B7800...need some stick out beyond the rear tires to make cutting close to things easier if you need to do that sometimes.
   / is a b7800 to big #10
If your septic system is at all marginal in its ability to
handle its job, and you may not be able to tell its not always
a good idea to drive anything on the drainfield but a very
light mower. Not for breakage, but for soil compaction.
Sure, all kinds of people drive their cars over their field
with no problem...but a lot find out the hardway.
Septic systems are designed so a lot of the liquid evaporates
upward as the pipes are not far below the surface. For best
operation, low native ground cover is best, or grass cut with light rider. You have to be careful with bigger plants,
some like to snake roots down the pipes and really cause a
problem. Maples and willows for instance.
Actually your heel puts down more weight per sq inch than
most tractors.
Even on the little tractors the tires keep getting wider
so maybe the compaction won't occur.
If you do ever find the system is suddenly not working as
well you can lightly break up the top 6 inches and that should
restore the breathability of the soil.
I've seen people have a problem and have a septic guy come
out and tear up their system only to find the pipes are clean
the soil is not sludged. Huge bill when all is needed is to
restore the upward motion of the liquid (er moisture)
As to breaking the tank, unless your state has really lax
standards or the tank was built before current standards
you probably couldn't break the top no matter what you drove
on it. The inlet pipe you might if it is real close to the
surface. When I first bought my place I had phone lines put
in, the phone company didn't ask where the tank was and I was
ignorant of the fact that you can't trust anyone else to know
what should be in their job description (knowing what they
are plowing through).
They plowed back and forth across my tank, broke the removable
lid but didn't hurt the tank.
Is your property all "done" otherwise, landscaped, no woods
to clean up? I think long term the BX may be something you'd
have a use for. The bigger tractor may be overkill, but as
most everyone will tell you, they had no idea of all the things
they'd find to use their tractor for after they bought it.
I think it comes down to (as the other fellow said) the seat
and the controls. You should really spend a couple of hours
at the dealer driving back and forth, stop and go, on and on.
Waste of a couple of hours to some, but you'd be surprised at
how uncomfortable one tractor may be FOR YOU over the other, and not
just the smaller one. Drive it over the ground as rough
as you have at home. If you have made up your mind to buy
it from a particular dealer, many dealers will bring out
both for you to demo. Staring at the brochure and the
sitting tractor leaves SO much out of equation.
Are you SURE in a few years you won't be buying that 5
acres up in the mountains for the cabin you've been
thinking about? Then you'll want the bigger tractor.
Both are light enough to tow with a many 1/2 ton pickups.
If you plan on doing much grading or use of a rear dirt
implement a tractor with position control on the 3 point is
IMHO required. I didn't even know tractors didn't have this
until I started using my BX. My bigger Ford is SO much easier.
The B7800 and I think all the other Kubotas have this. Maybe
the new BX's do too I haven't checked.
The JD2210 does not. A cost saving measure I suppose.
Some people say they get used to it, I guess if you didn't
have position control before you don't miss it.
The BX turns around really tight, I used mine inside a building
sometimes moving engines around. Sort of an indoor outdoor
power wheelbarrow!
del
Ford F250 (A45336)
Ford F250 (A45336)
2005 Chevrolet C5500 Flatbed Truck (A44571)
2005 Chevrolet...
Blue Bird 19" Lawn Aerator (A45336)
Blue Bird 19" Lawn...
INOP Skid Steer Backhoe Attachment (A44391)
INOP Skid Steer...
2021 Ford F-150 4x4 Crew Cab Pickup Truck (A44572)
2021 Ford F-150...
Volvo SD-100D Single Drum Vibratory Dirt Compactor (A44571)
Volvo SD-100D...
