Is "breakout force" the amount a loader will lift?
   / Is "breakout force" the amount a loader will lift? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Dumb question but I've always wondered how much my Deere 5520 with 541SL loader will lift. It's a lot because several times I've lifted more than I thought possible. In the site shown below the data is listed for the 5520 tractor with 541 loader and "breakout force" is listed at 4125 lbs. I have a self leveling loader and I think that's the "MSL" listing. Is breakout force how much it will lift?
TractorData.com John Deere 5520 tractor attachments information
   / Is "breakout force" the amount a loader will lift? #2
No. Breakout force is the curling up of the bucket. It uses different cylanders than yhe lifting arms. Typically the breakout force is more force than the lifting arms.
   / Is "breakout force" the amount a loader will lift? #3
Breakout force is how much the loader will lift off the ground. Lift force diminishes as height increases. Breakout is sometimes speced at the pins ... sometimes at a defined point in the bucket.
   / Is "breakout force" the amount a loader will lift? #4
And yet for even one more answer, Breakout force is the combination of the lift cylinders and the curl cylinders both operated at the same time at ground level to break out of the pile. Sometimes measured at the bucket lip, sometimes measured at the pins...
As 10 tractor geeks what breakout force is and you WILL get 10 different answers.
   / Is "breakout force" the amount a loader will lift? #5
.. Breakout force is the curling up of the bucket. It uses different cylanders than yhe lifting arms. Typically the breakout force is more force than the lifting arms.
I've always interpreted or read in FEL's OM to be just that & don't recall ever seeing a 'breakout force' rating not well above 'lift at pins' or similar to any height. When digging into a well settled pile to a near stall, the bucket will usually curl when the loader won't lift. Isn't that what breakout is?
btw, I've been grubbing brush & saplings with 800lb (lift) rated FEL. When the 'lift' runs out of muscle (and apparently better than revving any higher) a curl of the bucket will consistently 'git 'er done' :), ... or lift the rear wheels. :(
What's interesting to note is that the 'boost' comes with cylinders retracting vs extending. :scratchchin: tog
on edit: James, ok you won that race. ;) (I'd say BOF is measured at the lip ... and lift cylinders presumably locked when not actuated ... )
   / Is "breakout force" the amount a loader will lift? #6
How can u do a combination on a measure at the pins?
   / Is "breakout force" the amount a loader will lift? #7
Lift from a pile at ground level moves the bucket forward as it rises. ... A pretty tuf task if youre pushing too.
   / Is "breakout force" the amount a loader will lift? #9
Say when I'm in a pile of wet clay and the boom well not lift up, also it well not curl. Now if I let weight off of the boom and curl at the same time using the back of the bucket as a pry bar the rear well come up or it brakes loose from the pile. What would you call that.
   / Is "breakout force" the amount a loader will lift? #10
It sure seems like it oughta be called breakout, but as an incident rather than a known force.
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A55745)
2018 LARK UNITED...
Rooster Weathervane (A55853)
Rooster...
2018 Chevrolet Impala Premier Sedan (A59231)
2018 Chevrolet...
2013 Dodge Durango (A53317)
2013 Dodge Durango...
New Holland 650 Hay Baler (A53317)
New Holland 650...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
