Is there anyone that can lathe a bushing?
   / Is there anyone that can lathe a bushing? #1
Aquamoose
Platinum Member
Deer Park, WA
Branson 3520h
I have one to copy from. It’s lightweight material but I’d settle for machine able brass. I have all the measurements & pics.
   / Is there anyone that can lathe a bushing? #2
I would do it, even for free. However, the shipping would be crazy and most likely would still get lost in transport...
I'm sure someone closer will help you. 👍
   / Is there anyone that can lathe a bushing? #3
You're missing several dimensions one would need to duplicate that. Have you looked at McMaster Carr?
   / Is there anyone that can lathe a bushing? #4
ID
OD
Shoulder OD
Shoulder thickness.
Likely a stock item, maybe not even specialty.
   / Is there anyone that can lathe a bushing? #5
You should try searching in inch sizes also. Might not find it in metric.
   / Is there anyone that can lathe a bushing? #6
That looks like a lawnmower wheel bushing, if you get the rest of the measurements maybe able to find one.
   / Is there anyone that can lathe a bushing? #7
I use American Sleeve Bearing in CT. They made the diff bearings for my VAC. They where super easy to deal with and helpfull.
   / Is there anyone that can lathe a bushing? #8
Think you mean 'turn' the bushing. A 'Lathe' is the tool that turns it. Your best bet would be a 660 oil impregnated ( sintered) bushing and I bet you can find one somewhere.
   / Is there anyone that can lathe a bushing? #9
Our feed and hardware store sells them.
   / Is there anyone that can lathe a bushing? #10
See if you have a local bearings distributor. Last time I needed one, it was Bearings, Inc., a local place with a sharp counter person. Kinda like Fastenal, but for power transmission products.
I second McMaster Carr, if you have to order it.
1995 HESSE CORPORATION BEVERAGE TRAILER (A53843)
1995 HESSE...
2019 Doosan LCV6W Towable LED Light Tower (A54811)
2019 Doosan LCV6W...
2014 Dodge Avenger Sedan (A51694)
2014 Dodge Avenger...
UNUSED Black Vinyl Coated Lawn Fence Rolls (A53117)
UNUSED Black Vinyl...
2017 JOHN DEERE 350G LC EXCAVATOR (A52705)
2017 JOHN DEERE...
SCAN TO RECEIVE TEXT UPDATES (A52705)
SCAN TO RECEIVE...
