Is there anyone that can lathe a bushing?
   / Is there anyone that can lathe a bushing? #1
Aquamoose
Platinum Member
Deer Park, WA
Branson 3520h
I have one to copy from. It’s lightweight material but I’d settle for machine able brass. I have all the measurements & pics.
   / Is there anyone that can lathe a bushing? #2
I would do it, even for free. However, the shipping would be crazy and most likely would still get lost in transport...
I'm sure someone closer will help you. 👍
   / Is there anyone that can lathe a bushing? #3
You're missing several dimensions one would need to duplicate that. Have you looked at McMaster Carr?
   / Is there anyone that can lathe a bushing? #4
ID
OD
Shoulder OD
Shoulder thickness.
Likely a stock item, maybe not even specialty.
   / Is there anyone that can lathe a bushing? #5
You should try searching in inch sizes also. Might not find it in metric.
   / Is there anyone that can lathe a bushing? #6
That looks like a lawnmower wheel bushing, if you get the rest of the measurements maybe able to find one.
   / Is there anyone that can lathe a bushing? #7
I use American Sleeve Bearing in CT. They made the diff bearings for my VAC. They where super easy to deal with and helpfull.
   / Is there anyone that can lathe a bushing? #8
Think you mean 'turn' the bushing. A 'Lathe' is the tool that turns it. Your best bet would be a 660 oil impregnated ( sintered) bushing and I bet you can find one somewhere.
   / Is there anyone that can lathe a bushing? #9
Our feed and hardware store sells them.
   / Is there anyone that can lathe a bushing? #10
See if you have a local bearings distributor. Last time I needed one, it was Bearings, Inc., a local place with a sharp counter person. Kinda like Fastenal, but for power transmission products.
I second McMaster Carr, if you have to order it.
2020 DRAGON ESP...
2008 Keystone Camper Mod. 311BHS (A59814)
2008 Keystone...
1996 Transbridge Detach Low Boy (A59814)
1996 Transbridge...
E-Z Trail 20' Head Cart (A59814)
E-Z Trail 20' Head...
CASE TV370B SKID STEER (A52706)
CASE TV370B SKID...
(2) POLY DRUMS (A52708)
(2) POLY DRUMS...
