Is there anyone that can lathe a bushing?
   / Is there anyone that can lathe a bushing? #1
Aquamoose
Platinum Member
Deer Park, WA
Branson 3520h
I have one to copy from. It’s lightweight material but I’d settle for machine able brass. I have all the measurements & pics.
   / Is there anyone that can lathe a bushing? #2
I would do it, even for free. However, the shipping would be crazy and most likely would still get lost in transport...
I'm sure someone closer will help you. 👍
   / Is there anyone that can lathe a bushing? #3
You're missing several dimensions one would need to duplicate that. Have you looked at McMaster Carr?
   / Is there anyone that can lathe a bushing? #4
ID
OD
Shoulder OD
Shoulder thickness.
Likely a stock item, maybe not even specialty.
   / Is there anyone that can lathe a bushing? #5
You should try searching in inch sizes also. Might not find it in metric.
   / Is there anyone that can lathe a bushing? #6
That looks like a lawnmower wheel bushing, if you get the rest of the measurements maybe able to find one.
   / Is there anyone that can lathe a bushing? #7
I use American Sleeve Bearing in CT. They made the diff bearings for my VAC. They where super easy to deal with and helpfull.
   / Is there anyone that can lathe a bushing? #8
Think you mean 'turn' the bushing. A 'Lathe' is the tool that turns it. Your best bet would be a 660 oil impregnated ( sintered) bushing and I bet you can find one somewhere.
   / Is there anyone that can lathe a bushing? #9
Our feed and hardware store sells them.
   / Is there anyone that can lathe a bushing? #10
See if you have a local bearings distributor. Last time I needed one, it was Bearings, Inc., a local place with a sharp counter person. Kinda like Fastenal, but for power transmission products.
I second McMaster Carr, if you have to order it.
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
Husqvarna Riding mower (A56857)
Husqvarna Riding...
BOX BLADE (A58214)
BOX BLADE (A58214)
2019 FREIGHTLINER CASCADIA DOUBLE BUNK SLEEPER (A59575)
2019 FREIGHTLINER...
14C SCRAPER (A58214)
