Is this right? I can tow MORE with a bumper pull than I can a Gooseneck?
   / Is this right? I can tow MORE with a bumper pull than I can a Gooseneck? #91
Note that the PDF says "Factory-Installed Trailer Hitch Receiver Options" you can change to a different receiver to get more capacity (up to your axle weight limits). Here are some rated for a 17-20k pound trailer with 2500-2700# of tongue weight: 2014 Ford F-250 and F-350 Super Duty Trailer Hitch Class V | etrailer.com
Aaron Z
I actually think it has a heavy hitch installed as it came with a sleeve that would reduce it for the 2.5" insert I will have to take a look. I ordered it with the goose neck fiver package so a couple of hundred buys me the ball and chain connection decisions eh?
   / Is this right? I can tow MORE with a bumper pull than I can a Gooseneck? #92
True, but those ratings (850# or 1850# max tw and 18,500# max trailer weight) are for for the OEM 2.5# hitch. The ones I linked have a max tw of 2500# or 2700# and a max trailer weight of 17,000# or 20,000#
Aaron Z
   / Is this right? I can tow MORE with a bumper pull than I can a Gooseneck? #93
Aaron Z
yes, but you are assuming that the limiting factor is the hitch for the ratings he posted. That may not be the case.
   / Is this right? I can tow MORE with a bumper pull than I can a Gooseneck? #94
It would appear that both Curt and Drawtite feel that the hitch is the limiting factor. Its not the rear axle (based on the 5th wheel towing specs) but it could be the frame.
Aaron Z
   / Is this right? I can tow MORE with a bumper pull than I can a Gooseneck? #95
When the sleeve is removed the opening is 2.5" which I believe is a class five hitch
The truck was ordered with the heavy 14,000 GVWR payload package, camper package, fiver/gooseneck prep and trailer tow package and the hitch has a sleeve that when removed brings it to the 2.5"
does anyone know if this is a class v hitch?
   / Is this right? I can tow MORE with a bumper pull than I can a Gooseneck? #96
2.5" means Class V, but not all are created equal.
Aaron Z
   / Is this right? I can tow MORE with a bumper pull than I can a Gooseneck? #97
Aaron Z
I will have to take a closer look, It is up at the farm, I bought the truck to haul a camper not thinking of an equipment trailer lol.
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A56438)
Bulk Lot of NEW...
2024 CATERPILLAR 255 SKID STEER (A60429)
2024 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
2016 Nissan Altima 2.5 Sedan (A59231)
2016 Nissan Altima...
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
