jinma 224 block heater
   / jinma 224 block heater #11
The pan on my 224 is cast with ribs extending out about 1/2 for cooling and spaced about 1/2 inch apart. Lower Rad heater is the only way to go......On mine at least........
   / jinma 224 block heater #12
</font><font color="blue" class="small">( The pan on my 224 is cast with ribs extending out about 1/2 for cooling and spaced about 1/2 inch apart. Lower Rad heater is the only way to go......On mine at least........ )</font>
Lower hose on my KAMA is all of 3" long John, including clamped overlaps. Actual gap between radiator flange and block flange is about 1/2". No way possible to fit an inline heater.
Wolverines come in at least six sizes/dimensions/wattages, and will heat the side of an oil pan just as easily as the bottom. I have a tunneled oil pan, because of the front drive shaft housing. No room to put a single Model 16 anywhere, so I installed a pair of 9.1s - one on either side of the tunnel. Ganged the wires into a single AC plug.
//greg//
   / jinma 224 block heater #13
I live near Buffalo NY and two winters ago we had a cold snap that lasted several weeks where the temps at night were below O degrees F. I had to use a torpedo heater aimed at the block for about 20 min. I have a grey market 22 hp Iseki, all I did was use a dial caliper and measure the lower freeze plugs and found they were 1 and 3/4 inch. I called auto zone and got several replacement plugs in case it didnt work.Then I went to the local ford/nh dealer and we found a block heater that was 1 and 3/4 inch. It was 50 bucks but was much better quality than the others Ive seen. It was 800 watts and was for a ford 4000. I plug it in for 1/2 hour and the entire block is warm to the touch tractor starts like its summer.
   / jinma 224 block heater #14
Did you use any RTV sealant on the plug or just tap it in with a socket and hammer??
   / jinma 224 block heater #15
John, the block heater fit like none Ive seen before maybe thats why it worked so well. I first bought a cheapo one form Kats but element was too large but the one from ford has what looks like a knife blade all the way around the edge.I lightly tapped it into the hole then it had a quarter inch bolt on the outside you tighten.Instead of the cheapos using rubber this one the metal blades expand and bite into the block.I never used any sealer and it hasnt leaked so far.
   / jinma 224 block heater #16
Greg
What size Wolverine heater did you use for your 454? I've ordered a 554 from Chip and expect to get it in mid-November. I want to order a heater and put it right on before everything gets all crapped up and the temperature gets too cold to be messing around out in the garage. Where I am in Western Massachusetts it gets down to -30, so I'm thinking I might need a little more heat than you need in Kentucky. I want to plug it into an automatic controller that will start warming it up so the oil will be nicely warm when I come out to plow in the AM.
I did note your installation included taking off the paint on the oil pan and gluing the heater to bare metal. Is that your own wisdom or was that in the instructions? If they include silicone sealer, I assume they must tell you to attach it to bare metal.
Did you go with a 240volt or 120 volt heater?
Thanks
Steve
   / jinma 224 block heater #17
According to Wolverine guidelines, the KM454 oil capacity is best heated with their 250W unit. But because of the irregular shape of the KM454 oil pan, the Model 16 wouldn't fit anywhere. So I opted for a pair of Model 9.1 instead. They're 1.5"x6" and put out 125W each. I put one on either side of the driveshaft tunnel, then spliced the two AC cords into a pigtail.
You don't need a timer, and you don't need a higher wattage Wolverine. That's why you purchase them according to your engine oil capacity. They have a thermocouple that brings the oil up to 125F, and keeps it there. Just plug it in when you anticipate using the tractor in the morning - and it will control itself overnight. With a properly sized and installed Wolverine on the oil pan, -30F temps would have me more concerned about making sure the radiator, battery, and fuel system don't freeze up.
The installation procedure I posted pretty much follows the Wolverine instructions. The heaters are self-adhesive, cured with oil pan heat. The silicon they include is for sealing the heater edges, so that dirt and moisture cannot work it's way between the heater and the pan.
From the standpoint of using less electricity, I'd have preferred 240v. But that would have meant running a new circuit out to the shed. I went the cheap route, and bought 110v versions instead.
//greg//
   / jinma 224 block heater #18
Just purchased one and installed it on my 284 LE, same installation on yours I beleive. See attachment for explanation. If it is too small to read just right click on it and copy it and then put it into a word processor page and blow it up. Block heater cost was $37.00 Cdn. Works like a charm.
   / jinma 224 block heater #19
Looks Good leslie428 ! She should wake up now.
Ronald
Ranch Hand Supply
   / jinma 224 block heater #20
A little late but here is how I did it with a John Deer block heater that fits into the radiator pipe. Good luck
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A59905)
2018 FREIGHTLINER...
Kubota RTV-X1140 4x4 Diesel Utility Cart (A59228)
Kubota RTV-X1140...
Willmar 4550 Wrangler Articulating Loader (A56438)
Willmar 4550...
2025 AGT YC-32G Saw Mill (A53317)
2025 AGT YC-32G...
2019 CATERPILLAR  XQ35 GENERATOR (A58214)
2019 CATERPILLAR...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
