John deere 820
/ John deere 820 #1
Agoldman
Laplace la
John deere 820 German and two farmall super av
Hello. I'm new to this forum. I just purchased a john deere 820 German for 800 dollars. It was running 2 years ago and they sat it up because the starter went out. I never installed a starter yet to crank it but is there any other problems I should look for on this model??
/ John deere 820 #2
I would check all fluids and give her a shot.
Welcome to the forum.
/ John deere 820
There also seems to be a oil leak where the pto lever goes in rearend. Is there a seal there???
/ John deere 820 #4
Before I spent money on a starter I'd check the fluids to be sure they were at the full mark,change fuel filter and tow start it to check operation of tractor. You will need a good battery as the fuel is controlled by an electric solenoid(pushing key in to activate/pull out to kill engine). Pto lever has an o-ring seal (parts key #3 R28776) but changing it won't be easy.
/ John deere 820
Thanks for the info. Goin mess with it today.
/ John deere 820
What is involved with changing the o ring on the pto lever?
/ John deere 820 #7
Change the antifreeze and use a real HD diesel rated antifreeze along with distilled water. Or you will be replacing the wet sleeves.
Flush the entire transmission/hydraulic system, change filter, clean screen and refill with Hy-Gard. Or be ready to pay for new brakes.
/ John deere 820
I'm more familiar with old farmalls, so where is the hydraulic filter located??
/ John deere 820 #9
Best to call 1-800-522-7448 then order the operators and service manuals. A few lines of info from Bubba on the Internet is a pale comparison to a manual written by the folks at JD that know the tractor inside and out.
/ John deere 820 #10
Hyd filter is on RH side under footrest. Before I spent a lot of $$$$$$$ on the tractor I would find out if it will run & operate correctly.
/ John deere 820 #11
Removing 3 pt cover then removing spring pin to get shift lever out of trans case to renew o-ring and reassemble in a very hard to access place. A very difficult task.
/ John deere 820
Thanks for the help. Will keep y'all posted. Anything else I need to know about these little tractors?? Are they reliable?
/ John deere 820 #13
Very reliable tractor. Bought one in 1972 and still running good today. Good to use for grading, bush hogging, cutting and raking hay, etc. o ly real problem rear hydraulic leak as mention by others but not a major issue. Agree need two good batteries. What is overall condition of tractor? If you decide you don't want to keep it, let me know for I might be interested.
/ John deere 820 #14
I remember when I sold those 3 cyl 820's when they were new. First tractors I had sold that were built in Germany and I was very skeptical. They turned out to be very good tractors just deliver them & forget them hardly ever any warranty work was performed on them.
/ John deere 820
I will let you know. The tractor is in fairly good shape. Sheet metal is decent just missing battery cover and side screens. It has a new clutch that was installed three years ago. It spent most of its life on a ballpark running a finishing mower. Overall it's decent. It does have turf tires on the rear and will be looking to replace them with regular tractor tires. If anyone knows where I can maybe get the sheet metal parts I need let me know thanks.
/ John deere 820 #16
Every now and again you can find leads on on E-Bay. Ascension Equipment in Gonzales can get new but oh so pricey.
/ John deere 820
Thanks for the info. Hopefully this week I can work on it and see what it will do. Hopefully it will run ok
/ John deere 820
/ John deere 820
One more ques, where is the dipstick for hydraulic and transmission,
UNUSED IRANCH IRTPL 10000Ib TWO-POST CAR LIFT (A60432)
UNUSED IRANCH...
Year: 2014 Make: Volkswagen Model: Passat Vehicle Type: Passenger Car Mileage: 135,272 Plate: Body (A56859)
Year: 2014 Make...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
2019 Caterpillar 259D Compact Track Loader Skid Steer (A59228)
2019 Caterpillar...
Deere 333G (A53317)
Deere 333G (A53317)
(20) ROLLS OF UNUSED KJ K1230-10 FIELD FENCE (A60432)
(20) ROLLS OF...
