John deere 820
   / John deere 820 #1
Agoldman
Laplace la
John deere 820 German and two farmall super av
Hello. I'm new to this forum. I just purchased a john deere 820 German for 800 dollars. It was running 2 years ago and they sat it up because the starter went out. I never installed a starter yet to crank it but is there any other problems I should look for on this model??
   / John deere 820 #2
I would check all fluids and give her a shot.
Welcome to the forum.
   / John deere 820
There also seems to be a oil leak where the pto lever goes in rearend. Is there a seal there???
   / John deere 820 #4
Before I spent money on a starter I'd check the fluids to be sure they were at the full mark,change fuel filter and tow start it to check operation of tractor. You will need a good battery as the fuel is controlled by an electric solenoid(pushing key in to activate/pull out to kill engine). Pto lever has an o-ring seal (parts key #3 R28776) but changing it won't be easy.
   / John deere 820
Thanks for the info. Goin mess with it today.
   / John deere 820
What is involved with changing the o ring on the pto lever?
   / John deere 820 #7
Change the antifreeze and use a real HD diesel rated antifreeze along with distilled water. Or you will be replacing the wet sleeves.
Flush the entire transmission/hydraulic system, change filter, clean screen and refill with Hy-Gard. Or be ready to pay for new brakes.
   / John deere 820
I'm more familiar with old farmalls, so where is the hydraulic filter located??
   / John deere 820 #9
Best to call 1-800-522-7448 then order the operators and service manuals. A few lines of info from Bubba on the Internet is a pale comparison to a manual written by the folks at JD that know the tractor inside and out.
   / John deere 820 #10
Hyd filter is on RH side under footrest. Before I spent a lot of $$$$$$$ on the tractor I would find out if it will run & operate correctly.
Topcon RL-H4C Laser w/Tripod & Grade Stick (A59076)
Topcon RL-H4C...
UNUSED AGT SSPOC HYD LOG GRABBER (A52706)
UNUSED AGT SSPOC...
2005 INTERNATIONAL 9400I MID-ROOF SLEEPER (A58214)
2005 INTERNATIONAL...
1992 CATERPILLAR 14G MOTORGRADER (A52709)
1992 CATERPILLAR...
405 (A52706)
405 (A52706)
2012 FORD F-250 SUPER DUTY (A58214)
2012 FORD F-250...
