Joystick Circuit Selector Button
   / Joystick Circuit Selector Button #1
Charlie_Iliff
Arnold, MD
Power Trac PT1845, John Deere 2240, John Deere 950, John Deere 755, Jacobsen Turf Cat II
It may be a while before I get pictures, so I'll post too many words.
After the testing and demonstration that Bubenberg and I did on Sunday, I can declare the modification of the hydraulic controls on my PT1845 to be a success. With the button on the joystick, I can control the mounting plate lift and tilt as before, then push the button and control the open & close of the 4 n 1 or the curl of the hoe or the angle of the snowplow without my hand leaving the joystick.
Now, when I mount the hoe or 4 n 1, I don't attach them to the aux PTO. Instead, I hook their hydraulic lines to the new ones from the diverter valve. Then, when I move the lever to the side, it tilts the attach plate, as before. When I push the button and move the lever to the side, the tilt stays the same and the 4 n 1 opens or closes, or the hoe curls, etc. And, if I have another function, the aux pto is still available, still on the right knee lever.
Caveat: It was expensive. I have about $420 in the modification. I think it can be done for a little over half that by careful selection of components. I bought the valve and handle with button from W.R. Long for $204.75 and $56.95 respectively, plus shipping. I then bought hoses, fittings and adapters from our local Parker shop, which is expensive, but top grade stuff. Those cost $145. It took a few hours of fiddling to decide what fittings to buy, and where the valve could be mounted. I've seen valves as cheap as $125 if bought in lots of 30, and I assume there are some around in that range. At lease $75 can be saved in the hose and fitting budget by careful selection and location of the valve to minimize angle fittings and adapters.
To assemble a kit, you will need a momentary contact button, or a sleeve for the joystick with electrical top button or trigger. You need a solenoid operated diverter valve, four hoses, and the fittings to assemble everything. The steps are:
1. Figure where the valve can mount so that six hoses get to it without interference.
2. Disconnect the hoses from the joystick valves which go to the mounting plate tilt cylinder.
3. Install new hoses from the joystick valve to the p1 and p2 ports of the diverter valve.
4. Connect the original tilt cylinder hoses to the c1 and c4 ports of the diverter valve.
5. Connect two new hoses to the c2 and c3 ports of the diverter, with male quick disconnect fittings on the other end of the hoses of the same type as the aux pto.
6. Run one wire from the auxiliary pole in the console to the button, and the other wire from the button to the solenoid on the valve. Run a ground wire from the other solenoid valve to good ground.
Sounds easy, right? To make it challenging, do it in hot weather, as I did, and make sure you spill at least a quart of oil on the floor and an equal amount on your clothes. Preliminary testing with a couple of loose fittings does that well.
The type of valve which I installed is well described at <A target="_blank" HREF=http://www.autoguide.co.uk/sodad.htm>valve link</A>.
To select a valve from a hydraulic supplier, the best thing to do is to determine exactly what size fittings are on your PT system (are they SAE 4?). That way, a sodad can be selected which does not need adapters for hose sizes and fitting types. I used 6 $16 elbow fittings, plus a couple of similarly priced adapters from SAE6 to SAE4 (I think.)
A difficult decision is location of the new valve. I was able to squeeze it into the "firewall", but have noticed some minor interference with a lift cylinder when completely extended which might be a problem over time. Some imaginative location work may be needed on the PT425. A valve could be mounted outside the body, or on the boom, or even inside in the footwell with holes for a few hoses to go through.
The WR Long system I bought is oversize for PTs, but was assembled and tested by Long. I heard about it, and their 4 n 1 bucket which I bought, on TBN, and they have treated me well. Their kit is a proven way to go, and I think their price is not unreasonable, although money can be saved by assembling your own kit. Of course. if you realy get carried away, there are kits available with more buttons than on the average fighter plane, and the capability to add five or six new hydraulic circuits. Just think, a robotic grapple that tilts and swivels, that you can use to pick up your can of diet coke and pour it into your Chalkley cup, all while scratching behind your shoulderblade with a hydraulic backscratcher. (Don't press the wrong button.)
   / Joystick Circuit Selector Button #2
Charlie,
Great reading, this is a thread I will be saving.
PJ
   / Joystick Circuit Selector Button #3
Charlie, Thanks for the report. Are you able to move the arm of the hoe and curl the bucket at the same time?
It sounds like you and Hans had quite a day. Thanks for the research. I wish I could have been there.
Eric
<font color=red>Charlie, Thanks for the report. Are you able to move the arm of the hoe and curl the bucket at the same time? </font color=red>
Eric: The way I plumbed mine, I can curl the bucket while raising and lowering the whole assembly by moving the joystick to the side with the button pushed, and also moving it front to back. I can't move the dipper of the hoe by tilting the attach plate while simultaneously curling the bucket, since the valve switches the whole circuit to one or the other of those. I can get almost the same effect by pressing and releasing the button, since the change from one circuit to the other is immediate. I must confess, however, that even though all functions are now on one joystick, I tend to do one at a time, and generally fairly slowly due to lack of experience. Hans caught on fast enough to pick up big bites of branches and fence from the trash pile on his first try, which would have been much harder with the right knee lever.
   / Joystick Circuit Selector Button #5
Charlie, i spoke to Randy Lackender. He was reading your e-mail but said that he was very tired. We went over my order and the smaller mounting plate, thumb, 8" bucket and two teeth. Because of the smaller engine on the pt425 he is going to give me a smaller piston, i think he said a 2" one!?!?!?!
Randy said that it will take him a few days to get back to you but thinks that he can come up with a better, less expensive solution, alike his most expensive backhoe.
How are the caterpillars doing?
<font color=red>Because of the smaller engine on the pt425 he is going to give me a smaller piston, i think he said a 2" one!?!?!?!</font color=red>
Hans: I don't know the piston diameter of the cylinder on my hoe, but I think 2 1/2 inches is a reasonable guess. Mine is quite slow, but powerful. With the smaller cylinder, yours will move faster, assuming similar available flow in the control circuit that you attach to, but will only have about 2/3 the available force. Since I think you indicated you would be getting an 8 inch bucket, the force per inch of cut should be the same as my 12" bucket, assuming the same hydraulic pressure. I think the 2" cylinder should work fine, and should keep the function from being too slow for your usual impatient approach to things.
If the upload works, the attached photo will show the diverter valve about in the middle, with six hoses attached.
   / Joystick Circuit Selector Button #8
are we ever going to clean that dirt and grass of that machine ... or do you want to lock like us grasshoppers?
how are the caterpillar doing, by the way?
on Tuesday i have conference call with pt and terry specifically about what they intent to do about helping us (purchase and engineering power) about the supper button on your joystick, Wednesday i will follow up with randy lackender on the same subject.
   / Joystick Circuit Selector Button #9
Charlie, <font color=red>If the upload works, the attached photo will show the diverter valve about in the middle, with six hoses attached.</font color=red> Nice clean installation. Now when are you going to show us your button? Any idea whether Power Trac will offer us a mini hoe too, to say nothing of a dump trailer? And contrary to what bubenberg says I must compliment you on keeping your machine so clean.
<font color=red>are we ever going to clean that dirt and grass of that machine ... or do you want to lock like us grasshoppers?</font color=red>
I knew when I went down with the camera that someone would comment on a few grass clippings from the two fields I mowed Sunday. If I'd thought a bit more, I would have predicted who would point out that I don't clean after every use. My excuse is that my PT works for me, not the other way around. /w3tcompact/icons/laugh.gif
<font color=red>Now when are you going to show us your button?</font color=red>
Duh!! /w3tcompact/icons/blush.gif There I was, standing by the machine with a camera to take a picture for a thread about a button ...
Maybe next time.
   / Joystick Circuit Selector Button #12
i like the way the TBN lawyers went right to work for you ...hahahahahaha
i guess my comment about you joining the grasshoppers (prof. mowers ... ups ... what a word) was totally ignored, right mr. Sedgewood ... i am just kidding on both your accounts. furthermore Charlie did see the status of my pt and can comment freely about its cleanliness with over 400 hrs on the meter.
   / Joystick Circuit Selector Button #13
<font color=red> Because of the smaller engine on the pt425 he is going to give me a smaller piston, i think he said a 2" one!?!?!?![red/]
Hans, I have the 3" cylinder with the 12" bucket. As Charlie stated, it is slow but powerful. I've gotten used to it and I think it is less likely to jerk the lightweight 425 around. I think you're making the right decision by going with the faster cylinder for loading limbs with the thumb and the 8" bucket. I look forward to a report on your Lackender setup.
Charlie, Nice installation. Thanks for the pics.
Sorry about the ALL RED; I can't seem to get rid of it! I'm glad this isn't my bank acct. /w3tcompact/icons/laugh.gif
   / Joystick Circuit Selector Button #14
You put red slash. I think it is slash red /w3tcompact/icons/smile.gif
   / Joystick Circuit Selector Button #15
Where's my Visine?
   / Joystick Circuit Selector Button #16
bubenberg <font color=red>i guess my comment about you joining the grasshoppers (prof. mowers ... ups ... what a word) was totally ignored, right mr. Sedgewood</font color=red> Nope.. it jumped right over my head!
   / Joystick Circuit Selector Button #17
great to hear from you carpenter your imputes are always to the point .... use that thing allot and give us "somemore" good pointers .... any snow yet?
thanks
hans
   / Joystick Circuit Selector Button #18
Awesome write up Charlie. I too will save this thread so if I ever decide to get this ambitious I'll have a road map. First though, I'm inspired to rig up a pressure guage and on-board bleed/purging system for the hyd pump...basically a couple of tees, a few hoses, a spare oil filter and some diverter valves.
Thanks for sharing your experience in such detail!
Button
<font color=red>Now when are you going to show us your button? </font color=red>
You mean this button?? /w3tcompact/icons/smile.gif
   / Joystick Circuit Selector Button #20
Re: Button
Oh, that button /w3tcompact/icons/laugh.gif
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
2016 CATERPILLAR D5K2 XL CRAWLER DOZER (A60429)
2016 CATERPILLAR...
2005 CATERPILLAR 345CL EXCAVATOR (A60429)
2005 CATERPILLAR...
MARATHON 25KW GENERATOR (A58214)
MARATHON 25KW...
Toro MBTX-2500 Concrete Buggy (A54865)
Toro MBTX-2500...
New Holland Basket Rake (A56438)
New Holland Basket...
